The
The Dork
6/19/17 6:53 a.m.
What is the best rattle can coating for a cheap roof rack? Plastic dip, rust o leom, $1.00 per can paint, should I prime it? It is new and will see limited use. thanks in advance.
ProDarwin
ProDarwin PowerDork
6/19/17 8:19 a.m.
If its new, why do you need to paint it?
6/19/17 8:23 a.m.
Rustoleum, plasti-dip is too fragile for that kind of use.
fanfoy
fanfoy Dork
6/19/17 8:28 a.m.
ProDarwin wrote: If its new, why do you need to paint it?
This.
If you are afraid of stone chips, rattle can bed-liner would be a good way to protect the paint under.
pinchvalve
pinchvalve MegaDork
6/19/17 8:42 a.m.
Rattle-can or brush, the hammered finish is the easiest to make look good, and it is tough as nails. Anything outside that is metal, I trust this stuff.
The
The Dork
6/19/17 8:44 a.m.
All the reviews recommend painting it before it starts rusting and you have it own your car, like i it said it is one of the cheaper ones, thanks, jr
6/19/17 8:46 a.m.
^Based on what I've seen happen to most aftermarket roof racks, that's solid advice.
ProDarwin
ProDarwin PowerDork
6/19/17 9:19 a.m.
My Thule rack is old. Not sure how old, but I'd say at least 10 years. When I got it, the paint had just started to flake. I hit it in just those spots with whatever was on my shelf and its been fine since.
I honestly wouldn't worry about it until the factory paint becomes an issue. When it does, its only a few mins to pop it off the car, touch it up, and reinstall.
Furious_E
Furious_E Dork
6/19/17 10:24 a.m.
I second the bed liner idea, that stuff has become my go-to for anything on the exterior of my cars that requires a durable finish.
ultraclyde
ultraclyde UberDork
6/19/17 11:25 a.m.
I fabbed my own safari rack out of mild steel. I hit it with 2 coats of brush on Rustoleum and it's held up reasonable well. I just recently built a bike related cross bar for the new old truck and used a different type of spray paint, the Rustoleum 2X Ultra Cover. I don't know how it will hold up, but man it covered and layed down better than any spray I've ever used. I won't buy anything else from now on unless this just falls off or something. I suspect it will perform really well though, it seemed like a strong coating going on.
spitfirebill
spitfirebill UltimaDork
6/19/17 11:54 a.m.
I set out to use BBQ grill paint, but the SOB stopped up on me. I think I ended up using engine paint or something.
Hal
Hal UltraDork
6/19/17 6:36 p.m.
pinchvalve wrote: Rattle-can or brush, the hammered finish is the easiest to make look good, and it is tough as nails. Anything outside that is metal, I trust this stuff.
Good stuff! I rattle caned some aluminum patio furniture 5 years ago and it still looks good. And it sits outside all year.
DMi767oZIi1LaHX6k9dTF1lRywNZcymecqFq2bXiKksK3Sk9LhJB8xzhy70MUNwg
