I see a large amount of body work in my future and it will be a complete learning experience. While I have a nice compressor, it doesn't have a tank large enough to running a sander for long periods. hence the desire for electric.
I could see a palm sander being used on a car or perhaps a variable speed belt sander for rough work on bondo but I've never tried to use one for that.
Get some of these (they are very pumis like):
And one of these:
VERY good at taking off paint and bondo. Easy on metal also. I suspect much better than most air tool options. They also have smaller ones for detail work with drills. Complex surfaces will require wire wheels. I This has been my stripping solution. The only step up I see is a sand blaster (which of course will make much more of a mess)
I use a black and decker palm sander but im far from an expert. Wire wheel on a drill for tight areas and pitted areas.
i bought the harbor freight DA polisher, the most expensive one they have. then i bought the sanding backer pad with the correct threads, and switch them out. so i have an electric DA sander when i need to sand and polisher when i need to polish.
Can't think of any time I have used the electric random orbit sander that I have.
I use the wire wheel and the rice cakes on the angle grinder to deal with rust and crud. I have an air powered long-board, but find that it gathers dust since I bought a set of Durablocks with the stick-on sandpaper.
aircooled wrote: Get some of these (they are very pumis like):![]()
Amending my opinion. These are awesome, if pricey. The 3M ones that mount on a drill remove rust and paint well, also.But I think 80 grit on a DA would still be keen. I just bought an air DA for the same purpose because I got tired of the work/expense of the above. I cannot speak as to its effectiveness yet.
