Grtechguy
Grtechguy SuperDork
10/6/09 12:56 p.m.
Curious......any downfalls of using my shop vac to clean my aquarium? assuming everything submerged has been cleaned?
siphoning doesn't seem to get all the dirt and takes forever
aircooled
aircooled SuperDork
10/6/09 1:01 p.m.
Cleaning the shop vac. It could get pretty stinky pretty quickly.
EastCoastMojo
EastCoastMojo Dork
10/6/09 1:03 p.m.
Siphoning is the best way. It takes forever because you want to get the dirt without any more water than necessary. You don't want to change out more than 20% of the water at a time because it's hard on the fish. If it is taking too long or it's a large tank I would do half of the tank one week and the other half the next and rotate.
grinch77
grinch77 Reader
10/6/09 1:04 p.m.
go get a Python they work great for fresh water tanks and make it quick.
http://www.pythonproducts.com/aqprod.html
http://www.pythonproducts.com/a-gws.html
bludroptop
bludroptop Dork
10/6/09 1:07 p.m.
My first guess would be that it would be too powerful, and remove too much water (and gravel) too quickly. Are you putting the fish into a quarantine tank when you do the cleaning? If not, you could also run the risk of inhaling your livestock!
The chore of cleaning is why I eventually gave up on my 55 gallon saltwater tank. My water quality was always pretty good (had fish that lived for years, including a clown fish that was 9 years old), but I could never get the alge completely under control. A three hour cleaning routine every couple of weeks eventually turned a hobby into a chore.
Autolex
Autolex HalfDork
10/6/09 1:11 p.m.
grinch77 wrote: go get a Python they work great for fresh water tanks and make it quick. http://www.pythonproducts.com/aqprod.html http://www.pythonproducts.com/a-gws.html
I totally read that as in "you-should-get-a-reptile python"
EastCoastMojo
EastCoastMojo Dork
10/6/09 1:20 p.m.
bludroptop wrote: ... but I could never get the alge completely under control.
I found that interrupting the light cycle cured the algae problem. I set my lights on timers and had them shut off for three hours in the middle of the day, no algae problems after that.
AngryCorvair
AngryCorvair SuperDork
10/6/09 1:32 p.m.
EastCoastMojo wrote: You don't want to change out more than 20% of the water at a time because it's hard on the fish.
[Butthead] uh huh huh she said "hard on" huhhuh [/Butthead]
Grtechguy
Grtechguy SuperDork
10/6/09 1:38 p.m.
well...these are African Chiclids.... probably some off the most die-hard fish out there....not worried about shocking them too bad. they're all 4-5 inches and very healthy
fromeast2west
fromeast2west New Reader
10/6/09 2:53 p.m.
The flow rate on a shop vac is going to be orders of magnitude greater than what you should be getting with syphon/python system.
You can forget about the dirt and just do more aggressive water changes to get rid of the soluble waste. I'm not sure if there are any plants that will hold up to the appetites of the fishies you have, but that would help out too.
mrwillie
mrwillie Reader
10/6/09 3:19 p.m.
+1 on the siphon. I had underground filters in the last tank I maintained, and algae eaters for the algae. By not feeding too much and using good biofilters, I kept it pretty clean. You could see the fish anyway...
vz5PtIbQD8IviyiiLqVtEXsfYstZFNrEn0OTvU62SWFoskGmkffHWoKSALzvgtw1
