rob_lewis
rob_lewis UltraDork
6/16/17 10:34 p.m.
Might sound like dumb question, but searching for "crankshaft truing stand" or tool hasn't turned anything up.
I'm thinking about rebuild my son's single cylinder kart engines rather than paying a "tuner" to do it. I've seen in videos (and once in person) the truing stand the tuners use. The crank rests on 4 discs with a knife edge on them and then measure the trueness at the ends. I've they're not cheap (close to $1000), but since I don't know what to search for, I can't even confirm that. I'm assuming it's setup to be straight so you can use a dial indicator at each end and figure out how bent or tweaked the crank is.
Anyone on here know what I'm talking about? It's for a single cylinder crank, so it's not very big. Just trying to figure out the magic words.....
-Rob
daeman
daeman Dork
6/17/17 6:39 a.m.
Crankshaft checking bench or crankshaft check tool.
Either term should bring up what you're looking for.
NickD SuperDork
6/17/17 8:25 a.m.
Could you just use regular machinist V-blocks?
Slippery
Slippery SuperDork
6/17/17 8:37 a.m.
rob_lewis
rob_lewis UltraDork
6/17/17 8:49 a.m.
Thanks. I assume it was just not typing in the right combination of words to find it.
Honestly, I don't know why this is "better" than v-blocks, yet. I just assumed there was a reason one of the best tuners in the sport used them instead of v-blocks. Right now, it's just an exercise in costing and trying to learn as rebuilds after every 6 hours of running starts to get expensive.
-Rob
jimbbski
jimbbski Dork
6/17/17 9:44 a.m.
NickD wrote: Could you just use regular machinist V-blocks?
It's been done but not as accurate.
qZzDz5NtpGlWJIxLuuEH43jF8XoolTgHKS29nLhEEokqbVX7GiaSKsDAt068LDX5
