Remember when I said this was an experiment? Well, it's a successful one because I'm learning. That said, my current product is not what I want to end up with. The granules are unstable. Like a sandcastle, shape it wet and let it dry and it will hold shape until you touch it.
Supplied in my 10lb kit was a bag of dextrin, which is a binder. It'll keep the granules together very well, but it will foul the gun in a hurry. there are other binders, redgum, rice starch, others. These are still not ideal.
So I'm back to pressing the powder. I know this is what is done commercially. From what I understand (again, not a chemist) this causes the sulfer to plasticize and act as a binder.
Some reading suggests most folks use a 12ton press, but apparently the HF 6 ton press will work with slight modifications.
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2022/01/23/1642957469_14e41603-2d2b-4651-b7bc-329c03149ea9_mmthumb.png)
Then I'll need tooling. You can buy dies from the reloading suppliers or the chemical suppliers($$$), but apparently it's the drug folks who make the most cost effective solution.
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2022/01/23/1642957529_4cb4c155-83d6-41f9-b617-0a5851a7a5f1_mmthumb.png)
So. That's where I am at. I need to order some tools.
Now, this process is a little different and slower. Instead of putty, we just need enough water (not alcohol with this method) to keep the dust down. Load an oz or two in the die and slowly press until it won't anymore. Let sit for 10 minutes and remove the product and let dry thoroughly. This will give a solid and hard puck.
Once dry, use a rolling pin to crush it into granules. The results will not be uniform. Using the same screen I granulated with before, I'll filter out the usable powder (aiming for FFFg) and recycle the rest. Anything too large can be broken down, and anything too small can be wetted, dried, briefly milled again and reloaded into the press.
This method yields a 15-20% denser product. Denser explosions are more powerful and therefor require less volume per load. We're saving powder here, folks.
Quick math says the first 10lbs or powder costs around $250, but the tooling should last a very long time. 10lb of commercial product is currently about $300 if you can find any. Obviously the cost drops drastically after the first batch. Hopefully I can pick up the tooling soon, because I'm eager to keep learning. That said, I e got some personal stuff coming up soon and I'll be on a pretty strict limit for what I can lift and do physically for a couple months, so I'm really not in a rush.
