DrBoost
DrBoost UltimaDork
9/14/16 8:33 p.m.
I'm looking for a small USB hub that I can design into a charging base I want to print. So, I'm looking for a USB hub that charges 4 or more devices, but one that plugs into the wall, not a computer. I can only find ones that plug into a computer.
I'm sure someone will come up with a link in 10 seconds.... 9...... 8...... 7......
stuart in mn
stuart in mn UltimaDork
9/14/16 8:36 p.m.
Something like this? http://www.ebay.com/itm/like/171538507720?lpid=82&chn=ps&ul_noapp=true Search for 'USB wall outlet', there are many different types.
EastCoastMojo
EastCoastMojo Mod Squad
9/14/16 8:43 p.m.
Could you use a charger for a smartphone? They are pretty much just a wall wart charger that you plug a usb into. Use with any usb hub.
9/14/16 8:43 p.m.
If you're looking for a plug-in, there are about a billion of them. "USB charger 4 port".
I've used one like this for years. Probably picked it up at Home Depot.
Brian
Brian MegaDork
9/14/16 9:03 p.m.
I have a sabrent. 5 usb and a 3' cord.
Mike
Mike Dork
9/14/16 9:48 p.m.
Amazon search for 4 port USB charger. I suspect one of the top results is what you want. I have a 5 port that is pretty similar to the top hits. I'm assuming you need no hub function (that is, no data connectivity) at all.
jstand
jstand HalfDork
9/14/16 11:18 p.m.
You could also search for "powered USB hub" and get a wide selection to pick from, even if you don't need the data capability you could use one for charging.
EvanR
EvanR SuperDork
9/15/16 3:29 a.m.
jstand wrote: You could also search for "powered USB hub" and get a wide selection to pick from, even if you don't need the data capability you could use one for charging.
+1
I use an old USB powered hub as a standalone charger on my bench.
DrBoost
DrBoost UltimaDork
9/15/16 6:32 a.m.
Mike's Amazon link led me to what I'm looking for.
https://www.amazon.com/RAVPower-Charger-Charging-Station-Technology/dp/B00OT6YUIY/ref=sr_1_3?ie=UTF8&qid=1473938939&sr=8-3&keywords=4+port+charger+usb
Small enough to be build into the base of a charger, but plugs into the wall via a cord. Thanks all. When I design and print it, I'll post.
moparman76_69
moparman76_69 UltraDork
9/15/16 6:42 a.m.
https://www.amazon.com/Charge-RAVPower-4-Port-Charger-Galaxy/dp/B018S6X92I/ref=dp_ob_title_wld
This one has a quick charge port so if you ever have/get a quick charge enabled phone it will charge faster. Two bucks more than the one you posted.
DrBoost
DrBoost UltimaDork
9/15/16 7:56 a.m.
moparman76_69 wrote: https://www.amazon.com/Charge-RAVPower-4-Port-Charger-Galaxy/dp/B018S6X92I/ref=dp_ob_title_wld This one has a quick charge port so if you ever have/get a quick charge enabled phone it will charge faster. Two bucks more than the one you posted.
Thanks!
I'm going to design a charging station that will house the hub inside the base, with only the A/V power cord coming out.
yH8z0q2MBx5knAbYA36eEs2dP4jRWNi9Qtpbr01FmC2u0XqVdgF9Bu8ieFyZ6os7
