02Pilot
02Pilot UberDork
10/28/22 4:29 p.m.
Appliance in question is a GE front load 6cu ft dryer, model GTX18ESSJ0WW. Worked fine yesterday, today will not start. Breaker is not popped, but I cycled it anyway - no change. I partially disassembled and tested the door switch, start switch, internal 30A fuse, and the three of four thermal cut-offs I could get to for continuity and proper operation - all tested OK. There are no outward signs of trouble - no burned or pinched wires, nothing seemingly out of place. Where do I go from here, before calling the appliance repair company?
Slippery
Slippery PowerDork
10/28/22 4:32 p.m.
I was going to suggest fuse.
Does it do anything at all or is it completely dead?
Purple Frog (Forum Supporter)
Purple Frog (Forum Supporter) HalfDork
10/28/22 4:35 p.m.
In my past it has always been the door switch.   The switch may be good, but is it really getting tripped when the door closes?   I had one last month that the switch had moved in its mount and the door was no longer pushing it enough to register as closed.
02Pilot
02Pilot UberDork
10/28/22 5:17 p.m.
Seems to be completely dead. The door switch mount can't really move; it's mounted from the front, and the only way it could move back is if the lip broke off the switch, which it hasn't. I will try to manually close the door switch and see if I can start it.
Edit: It's the door switch. I held it closed and the dryer started. Now I just have to rig something to make sure it gets actuated. Thanks folks.
Slippery
Slippery PowerDork
10/28/22 5:25 p.m.
In reply to 02Pilot :
Lol good call Purple Frog!, glad you figured it out!
myT52v3NsEzkaWI8kY3GQnvfWJWwpPgmMof2ZUd5A9XpAlURXK5OUWD6VFxMvdyA
