pinchvalve
pinchvalve MegaDork
11/11/15 9:38 a.m.
Yep, the coil on the front passenger side of the Rondo snapped and collapsed overnight last night. Went to drive it this morning and the thing looked stanced. Parts were laying in the driveway under the car. WTF?
Had it towed, hoping that this is a warranty repair, just glad it didn't happen on the road at 80mph!
IMG_8879
IMG_8887
IMG_8882
IMG_8889
SkinnyG
SkinnyG Dork
11/11/15 9:48 a.m.
Co-worker heard a BANG! outside, and found his early late90's/early00's Pontiac Grand Prix "stanced" like yours. Apparently common on these.
Fueled by Caffeine
Fueled by Caffeine MegaDork
11/11/15 9:59 a.m.
Rond ho.. Say it ain't so.
tuna55
tuna55 MegaDork
11/11/15 10:05 a.m.
Wow.
I have seem evidence of broken springs in a similar manner, but always on cars far older and rustier than that.
Jerry From LA
Jerry From LA Dork
11/11/15 10:17 a.m.
Tom_Spangler
Tom_Spangler UltraDork
11/11/15 10:27 a.m.
Back in the 90s, a friend of mine had the front torsion bar break on his year-old PN96 F-150. Same thing, came out to the parking lot and it was down in the left front corner. Apparently they had a run of bad parts.
novaderrik
novaderrik UltimaDork
11/11/15 12:47 p.m.
neat.. in that one pic of the broken spring, you can see where the break started.. that one spot with what looks like rust in it was probably a factory defect that acted as a stress riser... it could have gone at any time from the moment someone in a sweat shop somewhere put that spring on that strut..
RX8driver
RX8driver Reader
11/11/15 6:15 p.m.
Springs are highly stressed with the highest stress at the outside, so that rust spot is almost certainly the cause. I'd at least give the rest a thorough inspection.
curtis73
curtis73 PowerDork
11/11/15 6:54 p.m.
I had a leaf of a spring pack break at a stoplight once. Just sitting there and "PNNNGGG." F150. It wasn't even rusty.
Brian
Brian MegaDork
11/11/15 7:31 p.m.
On a 4 year old '99 Taurus.
EvanR
EvanR Dork
11/11/15 8:19 p.m.
My sister had it happen on a 1-year-old Chevette.
Then again... it was a Chevette.
chandlerGTi
chandlerGTi UltraDork
11/11/15 8:22 p.m.
Six year old caravan, nuts.
WOW Really Paul?
WOW Really Paul? MegaDork
11/12/15 12:00 p.m.
Common issue with springs really, some fail out of the blue, some never do.
This is probably in retaliation for your Rondoing....
Knurled
Knurled MegaDork
11/12/15 12:31 p.m.
RX8driver wrote: Springs are highly stressed with the highest stress at the outside, so that rust spot is almost certainly the cause. I'd at least give the rest a thorough inspection.
Maybe not cause, but evidence of a crack forming. Small crack works water in and the contant motion makes a little powder which rusts more easily than solid steel.
11/13/15 4:53 a.m.
Had an airbag blow right next to me on a front discharge Oshkosh cement mixer. Sounded just like a shotgun.
MadScientistMatt
MadScientistMatt UberDork
11/13/15 7:47 a.m.
Now... where did the lower spring perch go?!?
mrhappy
mrhappy HalfDork
11/13/15 8:36 a.m.
In reply to MadScientistMatt:
Its up there by the top of the tire.
The_Jed
The_Jed UberDork
11/13/15 9:14 a.m.
Your abs wire is threaded through your coil spring and there are rub marks on the spring and the tire.
Almost like it broke while you were driving forward and dropped onto the tire then corkscrewed downward by rubbing on the tire, looping the end under the abs wire in the process.
lHWJ25WK9vhFLJNwBUd7kwQnr0FJkV7fhfUZoP9yY7z38jczEHIeEVqS69sA7asm
