chandler
chandler PowerDork
12/28/19 7:23 a.m.
Bought this old yellow jacket the day after Christmas, it has a 5h Briggs on it but no control for the choke. I can't find a picture of one with the same setup so I'm thinking this engine came from something else that had a lever for the choke. What is the best way to control the choke from the seat?
Is there a calculator to figure out revolutions of the engine to match them to gearing?
VegasNick
VegasNick Reader
12/28/19 7:28 a.m.
Don't see the pic, but most of the ones we built or even raced, had the Briggs slide choke. If it's a butterfly choke, we never had a cable.
Our most common gearing was around an 18: 56 or close to that.
Tire size plays a big part in the calculations.
https://www.gokartsupply.com/ratios.htm
RossD
RossD MegaDork
12/28/19 7:37 a.m.
Just let it idle a bit then open the choke up. If you cant run it without operating the choke while driving, you need to clean the carb.
1988RedT2
1988RedT2 MegaDork
12/28/19 8:16 a.m.
This.  I've never seen one that needed the choke except to start and run for maybe the first minute.  Unless it's running too lean, as noted above.
The 5 HP B&S on my kids' old kart, I would pull the slide choke.  Start the engine, then gradually push the slide choke back in, fully in within 60 seconds or less.
chandler
chandler PowerDork
12/28/19 8:37 a.m.
Ok, probably needs cleaned then. It sat for years so not surprising.
iceracer
iceracer UltimaDork
12/28/19 1:02 p.m.
In reply to RossD :
Yep, no need for the choke when driving.
There are charts to figure the gearing,  I have a "wheel" that does it.
9jXpaz13VNUJJWdPrxs77ylvEnUL3vePc7fukkCQbvHucJmzkZiV8tUje5fvcj6M
