joey48442
joey48442 SuperDork
7/17/11 10:31 p.m.
The stuff is 41 bucks for 100 feet at the home depot. Any place have it cheaper?
Thanks,
Joey
Grtechguy
Grtechguy SuperDork
7/18/11 6:52 a.m.
Grainger?
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=low+voltage+wire&op=search&Ntt=low+voltage+wire&N=0&sst=subset
mad_machine
mad_machine SuperDork
7/18/11 8:32 a.m.
zip cord? Sometimes referred to as "lamp cord" is the two pole flexible wire most lamp manufactorers use when they connect the lamp to a wall. It's pretty cheap, pretty weather resistant, and pretty flexible stiff.
You can also get "add-a-taps" for it
Strizzo
Strizzo SuperDork
7/18/11 8:52 a.m.
seems like that stuff was similar to the cheap speaker wire you can get at radio shack. might not be able to get green or black though.
joey48442
joey48442 SuperDork
7/18/11 11:06 a.m.
Ah cool. So there's no reason to use the actual landscape stuff? I cam bury the speaker or lamp wire?
Joel
stuart in mn
stuart in mn SuperDork
7/18/11 12:11 p.m.
You want wire that's rated for underground and/or outdoor use. Speaker wire or zip cord are not.
mad_machine
7/18/11 6:00 p.m.
I should have noted if it was being buried or not.
triumph5
triumph5 Dork
7/18/11 6:32 p.m.
You also might want to note that some critters--squirrels--actually LIKE to eat the plastic coating of certain wires. I'd imagine the landscaping wire is designed not to be tasty.
Kf6oWq9UaHJdyZkfdyamtFSnJsVQBSfeTjys5dlvvS9qWOAshC8kpKIOA7iKnihc
