Graefin10
Graefin10 Reader
6/9/11 4:13 p.m.
In reply to aircooled:
There were several times I could catch you in the Firblade but there was no room for a clean pass. Sure was tempting a couple of times though
I'll work on your advise on braking while following. Makes sense. Watching the replays this morning revealed several areas I need to work on in order to improve. Braking is #1. I noticed both you and Apex going way deeper into several key turns than I did.
Yes, White Volvo. I don't recall that one. I was so tired I put the brain in auto. pilot for that one. I ran a couple of qual. laps near my record @ Tsukuba though. I gave no thought to tire preservation and burned them off coming out of the corners. That let you and Apex by. I knew I had nothing to loose so I ran too deep in the last turn, last lap hoping to find a way around Apex and ran off into the sand. I've been buying potential HH contenders ever since it was decided we'd run them next and finally settled on the Volvo. I was very tempted by the CRZ though. I don't understand how that car can be so fast. It's so close to the Volvo it's tempting. My actual favorite though is the Honda Civic R. I'd love to have a real one.
T.J.
T.J. SuperDork
6/9/11 6:06 p.m.
Graefin10 wrote: T.J., I slammed you hard early on lap 1. I think you braked or let off the throttle before I did and even though I was on the brakes I hit your rear bumper hard. I don't think either of us suffered damage or a penalty though. I didn't and would like to know if you did.
I didn't get damage or a penalty from that hit, but it did send me off into the sand. Went from P2 to P last on the deal. I'm pretty sure I was holding the train up at that point anyway. I figured I'd already be in the back of the pack by then, so when Ieft the GP track in P2 I was a bit shocked.
Graefin10
Graefin10 Reader
6/9/11 6:34 p.m.
In reply to T.J.:
Oh man, that's worse than I thought! Sorry about that. Hopefully I can enact ac's. advice in the above post about how to follow entering a corner.
Apexcarver
Apexcarver SuperDork
6/9/11 8:47 p.m.
I really dont know how I pulled out that kind of distance in the caterham race. I was suspecting that I was the only one to brave the SS tires. (I was thinking if they didnt last, the speed difference might compensate for a pit stop, plus easier to drive.
Grae, let me know what you think of the retuned suspension. The rear will slide, but it wont bite unless you somewhat abuse it. At the end of the SBC race I was wearing out. That is the reason I spun it a few times in the last lap.
Back with GT4 I did a lot of lapping of the ring. so I guess I do somewhat have it memorized (which helps a lot!) the other thing is that I was concentrating on not pushing too hard. Just feed it into and out of the turns and maintain speed. Ended up working out for me I guess.
BradLTL
BradLTL HalfDork
6/10/11 10:09 a.m.
For some reason I forgot to save the SBC race, but here are some pics from the Fireblades...
Nürburgring Type V
Nürburgring Type V_1
Nürburgring Type V_2
Nürburgring Type V_3
Nürburgring Type V_5
Nürburgring Type V_4
Nürburgring Type V_6
Nürburgring Type V_7
Nürburgring Type V_8
Nürburgring Type V_9
Nürburgring Type V_10
Nürburgring Type V_11
Nürburgring Type V_12
Nürburgring Type V_13
Nürburgring Type V_14
Nürburgring Type V_15
Nürburgring Type V_16
Nürburgring Type V_17
Nürburgring Type V_18
Nürburgring Type V_19
Nürburgring Type V_20
Nürburgring Type V_21
Nürburgring Type V_22
Nürburgring Type V_23
Nürburgring Type V_24
Nürburgring Type V_25
Nürburgring Type V_26
Nürburgring Type V_27
Nürburgring Type V_28
Nürburgring Type V_29
Nürburgring Type V_30
aircooled
aircooled SuperDork
6/10/11 10:10 a.m.
I would have been on you for a bit Apex, if I didn't get that cut penalty. But you are correct about knowing the course. I don't know it that well (there is a lot to know) and had to be cautious in a few spots, so even if I was right behind you, you probably would have pulled away eventually.
I ran the soft tires also. They seemed to last fine. The only reason mine were a little worn was because of the spins.
Celica: I got the Europa back. I have to say I am surprised, it's not as radical a change as I suspected, actually quite drivable. You may not have the same reaction to he Pink Machine, I changed it a LOT.
92CelicaHalfTrac
92CelicaHalfTrac SuperDork
6/10/11 10:14 a.m.
aircooled wrote: I would have been on you for a bit Apex, if I didn't get that cut penalty. But you are correct about knowing the course. I don't know it that well (there is a lot to know) and had to be cautious in a few spots, so even if I was right behind you, you probably would have pulled away eventually. I ran the soft tires also. They seemed to last fine. The only reason mine were a little worn was because of the spins. Celica: I got the Europa back. I have to say I am surprised, it's not as radical a change as I suspected, actually quite drivable. You may not have the same reaction to he Pink Machine, I changed it a LOT.
I changed it big time when i was testing at Tsukuba, but softened it up quite a bit for The Ring. I didn't spend enough time practicing, took me a little bit to get the hang of it, then of course got dropped right as i did.
Your settings on the Pink Machine confused me badly.
However, that car is now wearing Racing Soft tires and a huge rear wing, and some more power. I think i'll be trolling some online rooms this weekend with it.
BradLTL
BradLTL HalfDork
6/10/11 10:16 a.m.
The 4 cars I've raced in the 2 GRM Series are shared online in their last race state. Have a spin, see how you do in them.
92CelicaHalfTrac
6/10/11 10:16 a.m.
BradLTL wrote: The 4 cars I've raced in the 2 GRM Series are shared online in their last race state. Have a spin, see how you do in them.
I've already had quite a few in your Mustang, thank you.
aircooled
aircooled SuperDork
6/10/11 10:33 a.m.
Good pics, I saved the SBC, so I will try and gets some pics if I remember.
Why are there so many pic of the orange car spinning?
A note on the Carousels at the ring: As I remember Graefin did a nice loop behind me on one. The trick (that I know of) is you have to go through them with NEUTRAL THROTTLE, just kind of glide through them. Interestingly, if you watch the video below (from another thread) you can see that when he goes through the Carousels, the g meter is centered accel / decel wise.
http://www.youtube.com/watch?v=5yKb6iSWc0k
(I can't test this link, so hopefully it works)
This is also just kind of interesting to watch after running the race. The depiction seems pretty accurate. He runs about the same speed as the Fireblades and seems to get a bit sideways in the same corners.
Graefin10
Graefin10 Reader
6/10/11 11:22 a.m.
I know what you mean about using nuetral throttle in the carousels. I just don't have enough finesse with the controller triggers to get it right every time I ran a few laps @ Monza sunny this morning and the Z06 should help me learn some finesse. I'm going to try to get a little better in the dry and then lock it on rain. Rain willl be a huge problem for both of the new classes.
Apex., I ran a whole lap of the Ring in the Cosmo and found it to be very driveable. It's definately not as tail happy as any of my settings. I never would have thought to soften up all the settings that much. I didn't have any major offs on that lap and could actually catch it if the rear came out. I got 155 top speed on the main straight.
Brad, it looked like you had a good set up on the Isuzu. Most of the time it looked good. I noticed it too was a little top end limited. I bought one of those because I sort of like the looks of it. Some day I'll get around to building it and giving it a shot.
It's interesting to take a good look @ that field of SBC cars. Each one of them chosen for different attributes. The Europa was a rocket off the line. The two FWD cars were had tiny engines and little torque but were very light wt. I suspect Celica might like Celicas. The Elan is quite fast in a straight line and . . . well I don't know what else. I chose the Cosmo because I was broke and didn't have time to seach the options like I would have liked to. It's also interesting to listen to the different engine sounds of all of them. I think the developers captured them quite well. The Isuzu sounds like a modified tractor engine
BradLTL
BradLTL HalfDork
6/10/11 11:26 a.m.
aircooled wrote: Why are there so many pic of the orange car spinning?
Orange is the slippery-ist color... or cause TJ and I picked the exact same color and neither of us had our best race.
I think I'll go with the former.
92CelicaHalfTrac
6/10/11 11:30 a.m.
I LOVE this picture.
Haters gonna hate!
BradLTL
BradLTL HalfDork
6/10/11 11:50 a.m.
92CelicaHalfTrac wrote: I LOVE this picture. Haters gonna hate!
Didn't know if anyone would catch that... hahahaha....
NickF40
NickF40 Dork
6/10/11 11:52 a.m.
word!!
T.J.
T.J. SuperDork
6/10/11 12:02 p.m.
Brad, our oranges are a bit different. Mine is a little darker maybe slightly coppery. If the driver is wearing a pink, then it is a pic of me.
Graefin10
Graefin10 Reader
6/10/11 12:09 p.m.
Nick, do you have any idea why your i/net won't stay connected during the race? The next series starts next Wed. and we need to see you there. I always put my computer to sleep during the races. I don't know why but my computer and PS don't like to be online simultaneously.
BradLTL
BradLTL HalfDork
6/10/11 12:50 p.m.
Graefin10 wrote: Nick, do you have any idea why your i/net won't stay connected during the race? The next series starts next Wed. and we need to see you there. I always put my computer to sleep during the races. I don't know why but my computer and PS don't like to be online simultaneously.
I don't know what you guys do to piss off your PS3 so much. I don't shut anything down. Could it be firewall settings?
92CelicaHalfTrac
6/10/11 12:56 p.m.
Mine is just ATT and their shady business model.
NickF40
NickF40 Dork
6/10/11 1:39 p.m.
I don't know man, I really don't know. My PS3 is close as hell to the router, I fixed my DNS stuff, I have 85-100% signal, I have Type 2, I just don't understand it. I notice also if people not in our group join it screws me all up to. I know Graefin, I want to be there to! Even with no computers on and my phone off still. I have decent DSL and a router but still.....I just don't berkeleying get it Iwould mess with my firewall settings but that's the last thing I need is a virus on my computer or whatever
Graefin10
Graefin10 Reader
6/10/11 2:01 p.m.
In reply to NickF40:
I have my PS plugged directly into the router with a 25' cable. How much trouble would it be for you to try that?
92CelicaHalfTrac
6/10/11 2:24 p.m.
Yeah, wireless was always sketchy for me. I plugged directly in and it helped a bit.
NickF40
NickF40 Dork
6/10/11 3:51 p.m.
Yeah, I probably should try that but I need more than 25' maybe, it's still ridiculous though
Graefin10
Graefin10 Reader
6/10/11 4:06 p.m.
Martwall has a 50footer
NickF40
NickF40 Dork
6/10/11 4:35 p.m.
My router is used for 2 other computers so I can't just plug it into the router, won't it mess all other devices up?
MD1wmLxxvWqDsQ4sA9muWVsaS318Sj9hXaShiGiAMGTHywSBd63swFB16xYkuZUB
