curtis73
curtis73 UltraDork
4/3/13 9:50 p.m.
I have an old house. All of the door latches are the old Mortise-style with the threaded shaft. They are all brass with about 6,573 coats of paint on them. I stripped several of the plates and knobs. I would simply polish them and re-install but I have chosen chrome or brushed nickel finishes for most of the rooms. Brass just looks like poop with the colors I've chosen.
I can buy new nickel Mortise locksets to replace them all, but that is expensive. I can repaint them but that is ugly. I thought of painting them with some kind of silver paint like a spray chrome, or hammered silver, but that is also a bit cheapy-looking.
Can I set up a couple rubbermaid containers and re-plate them at home? I've done some research and its described as "dangerous" and "caustic." Know of any links or sources for DIY plating?
Derick Freese
Derick Freese SuperDork
4/3/13 10:11 p.m.
Chrome plating will put you in contact with some pretty nasty stuff. Hexavalent chromium isn't something I'd really want to play with too often. I've tried a couple of the trivalent chromium plating kits, but it doesn't leave as durable of a coating.
http://en.wikipedia.org/wiki/Chrome_plating http://en.wikipedia.org/wiki/Hexavalent_chromium
wae
wae Reader
4/3/13 10:13 p.m.
Not really an answer to your question, but my Dad had something similar at his house and he used a media blaster to take the knobs and plates down to the bare metal and then sprayed them with a clear. They've got a nice finish that has held up for the last 6-8 years.
m4ff3w
m4ff3w UltraDork
4/4/13 12:27 a.m.
Didn't you learn your lesson about hexavalent chromium?
Derick Freese
4/4/13 1:36 a.m.
Oh yeah, I forgot about the EPA regs for disposal of the waste.
foxtrapper
foxtrapper PowerDork
4/4/13 4:37 a.m.
Very generally speaking, diy plating tends to look bad and fail quickly. Especially if you are attempting a chrome like finish.
spitfirebill
spitfirebill UltraDork
4/4/13 7:26 a.m.
I doubt you want chrome anyway. You could go with anodizing pretty easily I think. Cadmium plating could be done, but cadmium is a pretty bad hombre too.
There are a lot of new powder coating finishes other than just colors.
fanfoy
fanfoy Reader
4/4/13 7:55 a.m.
spitfirebill beat me to it. Try your local powder coater. I saw a guy last year who had the bumper powder coated with a "chrome" finish on his 60's something american barge. It looked pretty convincing, like a cheap chrome platting.
Rob_Mopar
Rob_Mopar SuperDork
4/4/13 8:27 a.m.
Take a look at Caswell Plating. Spend the $30 on their plating manual, then poke around their site to see if setting up all the gear is still cost effective for your project.
I looked into it a while ago, but then found some NOS chrome bits I was looking for that wound up being cheaper.
curtis73
curtis73 UltraDork
4/4/13 10:01 p.m.
Good info.... DIY plating looks nasty. I wouldn't mind trying it but I would need some kind of volume to justify the cost.
I think I'll strip a few pieces and try some other coating methods first.
b8K738G3EDmaCBfW7k3rgabc2RawCwZrLnhw5RGs7TGMmkzXLax1PiZinJS7aQVF
