Rusnak_322
Rusnak_322 Dork
10/15/15 10:52 a.m.
OK, my kid wants to be Lord Business from the Lego movie for Halloween. He has a school event tonight (Kindergarten). So I scrambled to make a costume including a helmet and shoulder pad thing (they are not connected).
I got it done last night, but the problem is, even though it is made from cardboard and foam, it is so top heavy that it moves on his head. I improvised and used an old bike helmet (with the adjustable rear part) but it still slides on his head.
I am thinking that I need to somehow tie it to his shoulder pads, but then he won’t be able to move his head. I have the shoulder pads attached around his mid-section with a Velcro strap, but they are cardboard and foam as well.
Any ideas? I pretty much am screwed for tonight, but I want it to work for trick or treating.
I also still need to make the Kragel.
10/15/15 10:58 a.m.
Quick idea, look into the big ridiculous headpieces like the ones used in Brazilian carnival, they have this problem solved somehow.
MadScientistMatt
MadScientistMatt UberDork
10/15/15 11:16 a.m.
Maybe use something like a football helmet that comes down lower on the skull in the back? That would give the helmet more leverage for bracing.
Wall-e
Wall-e MegaDork
10/15/15 11:20 a.m.
Duct tape
RossD
RossD UltimaDork
10/15/15 11:21 a.m.
Counter balance it on the back with something down low?
G_Body_Man
G_Body_Man Dork
10/15/15 11:45 a.m.
RossD wrote: Counter balance it on the back with something down low?
Only someone on this board would suggest turning someone's kid into a steadi-cam.
pinchvalve
pinchvalve MegaDork
10/15/15 12:32 p.m.
DO NOT USE DRYWALL SCREWS TO AFFIX TO THE HEAD
Something that size, I might vote to lock it to the shoulders and have his head move within it?
You could try to lighten it more?
Can it rest on the shoulder-pads and just slide around?
10/15/15 12:38 p.m.
OK so it looks like really big "professional" headpieces that are easily removable attach much like a hardhat:
In fact a lot of DIY'ers like to modify hardhats to make a base for large headpieces.
10/15/15 1:10 p.m.
Could you fill the horns with helium balloons? Seriously.
10/15/15 1:22 p.m.
Appleseed wrote: Could you fill the horns with helium balloons? Seriously.
Not worth it. When I was a kid I found that it took 2 helium balloons to lift a Lego man (not a kid dressed as a Lego man )
Grtechguy
Grtechguy UltimaDork
10/15/15 1:55 p.m.
In reply to GameboyRMH:
what sort of lego men did you have?
Rusnak_322
Rusnak_322 Dork
10/15/15 2:11 p.m.
GameboyRMH wrote: OK so it looks like really big "professional" headpieces that are easily removable attach much like a hardhat: In fact a lot of DIY'ers like to modify hardhats to make a base for large headpieces.
That is very similar to the bike helmet that I using with the spinning adjuster at the back, but the bike helmet also has the chin strap.
I went out at lunch and bought some of those clips that you use to attach kids gloves to a string between their sleeves. they look much stronger then suspender clips. I am going to try clipping the helmet to the back of his coat in two places first. if that doesn't work, I may make a chest strap and clip to that.
my wife has the idea of recovering his travel sleep pillow neck thing in the same red fabric that I used on the helmet to help hold up the helmet by taking weight off of it, but I think his neck is too long for that.
What I need is a very small HANS devise.
Jim Pettengill
Jim Pettengill HalfDork
10/15/15 2:43 p.m.
Modified suspenders?
Rusnak_322
Rusnak_322 Dork
10/16/15 7:20 a.m.
Everything is Awesome....
Fixed it. The straps at the back of the helmet didn't work. Then I realized that even though the helmet was tight on the sides and front, and the rear adjuster was tight against the back of his lower head, there was a lot of room at the back of the helmet. I took one of the purse size Kleenex packs and stuffed it in there and the helmet was solid. We went to the PTA preschool & Kindergarten party last night and it held up to him running around and bashing into everything. Like a longhorn steer making his way thru a crowd.
His costume was a hit. We had 5 or 6 people ask to take his picture (not as creepy as it sounds).
Here he is with his sister
bastomatic
bastomatic UltraDork
10/16/15 7:40 a.m.
That is awesome! Great job!
10/16/15 7:42 a.m.
Haha nice. Some big platform shoes would've looked good, but on the other hand I guess that would've just made the "longhorn steer" more unsteady
Rusnak_322
Rusnak_322 Dork
10/16/15 7:57 a.m.
Thanks, still thinking about making boot covers (along with a Kragle), but no stilts. He was Steve from Minecraft last year and fell over way too much.
rob_lewis
rob_lewis SuperDork
10/16/15 8:07 a.m.
Just wanted to say you're an awesome dad to create cool costumes like that!!
-Rob
pinchvalve
pinchvalve MegaDork
10/16/15 8:30 a.m.
  1. Great work on the costume.
  2. Will you be my dad?
stroker
stroker SuperDork
10/17/15 8:35 a.m.
rob_lewis wrote: Just wanted to say you're an awesome dad to create cool costumes like that!! -Rob
+1
JlMppNZZEvfF4sVXZFEYZbOT6pI4xStZvvBr4vRsWlvDK9HFVnvoXUReerjCJ1Yx
