8/5/17 6:59 a.m.
MIL lives in an old peoples' apartment complex, her neighbor has issues with her (2003?) Saturn SUV. She can drive about 5 miles then the thing shuts off. I asked "like someone flipped a switch or does it die a slow death choking its was to the curb?" She said like someone threw a switch.
THEN, once it sits for a few hours it fires right up like nothing happened.
When it happens idiot lights come on, no gauges. No CEL and there are no codes.
I was thinking a bad gas cap vent would shut it off but then come back to life once the tank vents and equalizes pressure, what do you think?
Thanks, Dan
DrBoost
DrBoost MegaDork
8/5/17 7:12 a.m.
Crank position sensor? It's early and I've had VERY little sleep the last few days, so I'm just shooting in the dark.
Stampie
Stampie SuperDork
8/5/17 7:18 a.m.
Clogged fuel filter only because I had that happen with a rusty K10 once.
vwcorvette
vwcorvette SuperDork
8/5/17 7:41 a.m.
Moisture. Coil pack cracked? No CEL, still check for codes that may be stored as soft codes.
EastCoastMojo
EastCoastMojo Mod Squad
8/5/17 8:18 a.m.
I had a Voyager that exhibited these exact symptoms, turned out to be the hall effect sensor. I have no idea if the Saturn VUE has one of those but I would check the crankshaft position sensor if it does not.
8/5/17 11:18 a.m.
Wouldn't these things show up with a scanner?
DrBoost
DrBoost MegaDork
8/5/17 11:31 a.m.
Sorry, I missed the no CEL part.
Check the battery cables. I've seen that many times. Not many other things willkill the engine like that and not leave a code behind
Johnboyjjb
Johnboyjjb Reader
8/5/17 1:43 p.m.
I was thinking valet key.
Fueled by Caffeine
Fueled by Caffeine MegaDork
8/5/17 4:31 p.m.
Battery or battery wiring issue
iceracer
iceracer UltimaDork
8/5/17 6:29 p.m.
A coil or something fails when it gets hot then works after it cools. Problem is, which one.
8/5/17 7:09 p.m.
I had that happen on a 95 9C1. It ended up being a failing fuel pump.
KyAllroad
KyAllroad PowerDork
8/5/17 8:43 p.m.
My money is on bad battery connection as well, my Suburban exhibited the same thing until I cleaned and properly tightened the cables. Tiger Mom was not amused when she was stranded at an intersection one day.
Pete Gossett
Pete Gossett MegaDork
8/5/17 8:50 p.m.
In reply to 914Driver:
Regardless of whatever the cause is, if it has a CVT transmission it's not long for this world regardless.
dean1484
dean1484 MegaDork
8/5/17 9:19 p.m.
Data log and see what stops working.
JtspellS
JtspellS SuperDork
8/5/17 11:36 p.m.
Battery & fueling is where I would start then start looking close at harness pinch points.
qJcpsu8NbChNlKqNLhr751JWpumS2f369pw83ep8Iqc1nbhK22Iv2WnCAWuM9Ova
