About the Whiteline end links (https://medium.com/@FlordPerformance/whiteline-refuses-to-honor-our-warranty-41767ae637af) - I don't really blame Whiteline here. A "universal" end link is not a guaranteed fitment on every possible vehicle, and it's up to the installer to make sure their particular application doesn't cause problems like rubbing. Damage from rubbing isn't a warranty item.
The thing to do here would have been to buy a set of end links with a good return policy and check them carefully through the range of motion to ensure there's no fouling. If there is, you return the end links in new condition and try to find another set with different geometry. I would not expect the manufacturer to send out "prototypes" unless they were trying to develop a specific application.
Those Superpro boots definitely failed, though. I wonder if they could have sent you some new boots?
After contacting Zeder Corp the owners of Superpro and Whiteline, Informing them that they Superpro end links failed after 2 years of use, Zeder Corp suggested that I contact Josh at Whiteline AU for a new set of their Whiteline end links.
My issue is that according to their specs, they did not have a set of end links for the Connect, But they had one closes enough that might work. based on Josh and Zeder Corps suggestions I purchased a set of their 10.5–11.50 inches adjustable end links. These typically known as universal links but once on the van, they’ve made contact with the struts, coil springs, sway bar and subframe.. the links are managed after only 2 months of having them installed.
Although this is not the best angle for the pic as I was more focused on the sway bar at the time, But one can see marred areas on the end link rods where they’ve made contact with several different parts of the chasses and this isn’t even the worse side either..
Deep maring was caused by the end links making contact with the van’s subframe during articulation and whiteline will not honor my warranty on this..
When I told Josh that I was sending pics of the damaged links, right off he said Whiteline would not honor the warranty on these links claiming we installed them incorrectly and I’ve yet to hear back from Zeder Corp.. years of talking to Zeder Corp and Josh at Whiteline down the drain simply because they refuse to honor a warranty on a product that’s suppose to be universal. There’s only one way to install these end links. Just another cop out to avoid honoring our warranty.
This all boils down to, yeah sure, looks good on paper, but when it comes to real world testing.. it doesn’t fit. At least they should have sent me a prototype set for test fitting first.. Just another expense we’ve lost due to trusting someone advice and paperwork. Today, we’ve lost nearly 2K on parts that didn’t fit, never arrived or arrived damaged and those company’s who sent these parts etc would not compensate us for their mistakes.
