z31maniac
z31maniac MegaDork
11/15/18 9:20 a.m.
SVreX said:
Ducts under a slab on grade are generally avoided because the risks of moisture intrusion are far too great to justify any advantages to such a system. They can end up with standing liquid water, pools of stagnant scum, thick mold, mildew, and thriving ecosystems. No way to fix it, either, once you realize you have a problem.
This is another reason running a camera down those ducts would be a really good idea.
Yeah, and the guy I spoke to that cleaned the vents said the "duct sealing" companies.........that those aren't cheap.
SVreX
SVreX MegaDork
11/15/18 9:31 a.m.
In reply to z31maniac :
COPD is not cheap either.
Patrick
Patrick MegaDork
11/15/18 9:33 a.m.
SVreX said:
In reply to dculberson :
It’s not uncommon in old slab on grade houses. It’s rarely done now.
They do it in all of them around here still.  I hate it.
Curtis
Curtis UltimaDork
11/15/18 9:45 a.m.
The real answer is airflow and circulation.  Booster fan in the duct, ceiling fans, etc.  The dirty way to do it is a series of box fans in the hallway (or a space heater in the bedrooms), but those aren't pretty options.
frenchyd
frenchyd UltraDork
11/15/18 10:20 a.m.
In reply to Curtis :
You could clean those up by putting them in walls with grills over them.
z31maniac
z31maniac MegaDork
11/15/18 10:34 a.m.
Do you mean store bought box fans and space heaters being put in the walls? If so, that sounds very "janky."
Ransom
Ransom PowerDork
11/15/18 10:37 a.m.
I feel like I've gotten some evening-out by setting the fan to "on" instead of "auto", so that it's constantly circulating air regardless of whether it's actively heating or cooling. Mixes all the air better, moving heat to cold places and vice versa.
I haven't used it yet, but our new place's thermostat also has a "circ" mode that runs it some percentage of the time.
SVreX
SVreX MegaDork
11/15/18 10:47 a.m.
“Janky” is Frenchy’s middle name.
Mr Frenchy Janky Cinderellacastle. cheekywink
z31maniac
z31maniac MegaDork
11/15/18 10:50 a.m.
Yeah, I hate to sound so snobby, but if you saw how nice the house is on the inside and outside, or my previous track car builds, "janky" is something up with which I will not put.
My 1.6 Miata had down to the subframes removed, bushings out, powdercoated, brakes pulled apart rebuilt and powdercoated, everything went back together with fresh bushings and literally every single bolt was replaced with new OEM from the Mazda dealer. And that was just the suspension and brakes.
That's just how I do things. laugh
NermalSnert
NermalSnert Reader
11/15/18 11:07 a.m.
The returns are in the ceiling and the vents are in the slab? How the hell...?
SVreX
SVreX MegaDork
11/15/18 11:19 a.m.
In reply to NermalSnert :
An air handler in the vertical orientation pulls air from one end and blows from the other.
Its pretty easy. It’s done all the time in slab in grade houses (though usually in reverse to OP’s scenario)
NermalSnert
NermalSnert Reader
11/15/18 11:22 a.m.
Thanks. I can see that after I thought about it for a min.
llysgennad
llysgennad New Reader
11/15/18 12:06 p.m.
If that's the norm, would it be possible to redo the ductwork at the furnace to reverse the airflow? Maybe that's how it's supposed to be and got changed somehow.
SVreX
SVreX MegaDork
11/15/18 12:34 p.m.
In reply to llysgennad :
Yes, but no.
Existing duct sizes will all be the wrong size and distribution.
He also said the house has a cathedral ceiling in the center. That means new ducting installed in the attic can’t be connected to the other side of the house easily.
It MIGHT be possible, but would likely cost more than $10K.
Zero chance it was ever intended in reverse.
mtn
mtn MegaDork
11/15/18 1:52 p.m.
Z31, in the interest of keeping it simple, cheap, and effective, for heating I’d use something like this: https://m.lowes.com/pd/Cadet-Register-1-500-Watt-120-Volt-Heater-Fan-Heater-4-in-L-x-7-375-in-H/1000062573
It looks just like a normal air register or return. It provides enough heat for a room. Hook them up to a nest (or whatever your preferred smart thermostat system is) and you’re good to go. You ultimately need multizone heating and cooling; this is the easiest and best way to do it on a budget short of having space heaters everywhere.
z31maniac
z31maniac MegaDork
11/15/18 2:31 p.m.
Yes, but no.
Yeah, that's just the dining room, you can see the windows above represent the even higher vaulted portion in the living room (right 3 windows) and the left 2 (master bed).
SVreX
SVreX MegaDork
11/15/18 3:22 p.m.
Good looking house.
llysgennad
11/15/18 3:46 p.m.
The boosters your boss suggested would be a good cheap test fix if you have airflow at those registers. If you don't, (tried the yarn test?) there's not much else you can do with the existing system. Ceiling fans might help some. Lots of options to supplement the system, from the heated registers and window AC units, up to a mini-split system. Might be able to do a 3-4" duct hidden in a false soffit if you can tap into the supply at the furnace.
Agreed, nice looking house
frenchyd
frenchyd UltraDork
11/15/18 3:58 p.m.
I doubt they would fit in typical walls.   At most you’d have 4&1/2 inches to work with. I was thinking something industrial. you wouldn’t need the “box” part.  Plenty of compact fans out there, just a matter of going through an industrial catalog or 2 ( doz)
You’ve  seen my house anything look “janky”?
ProDarwin
ProDarwin PowerDork
11/15/18 4:02 p.m.
This is why I have always wondered: if/when I build a house, is it better just to put in multiple ductless setups?  These issues go away, there is anywhere form some to a lot of energy savings, and you free up space normally consumed by ducts.
But yes, on that note, can you do some a simple ductless setup on the other end of the house?  I have a 3 bed 2 bath, and while all 3 rooms are heated/cooled evenly, I wish I had separate control over the other two.  They are used only several times a week vs. my bedroom which is used every night.
mtn
mtn MegaDork
11/15/18 4:23 p.m.
I would assume the answer is “it depends”. Large sprawling ranch? Probably. Small box? Probably not.
OHSCrifle
OHSCrifle Dork
11/15/18 4:40 p.m.
Non janky transfer fans in a couple walls might be a fairly simple fix. Cut some drywall, wire em up.
https://na.panasonic.com/us/home-and-building-solutions/ventilation-indoor-air-quality/ventilation-accessories/transfer
Edit:  alternately- moving your thermostat might be helpful as well.
Curtis
Curtis UltimaDork
11/15/18 5:10 p.m.
my suggestions is Very janky indeed.  But cheap until you figure out a real solution.  I wasn't talking about putting anything in the walls, just box fans sitting on the floor in the hallway.  Janky AND ugly.
But I live alone in a teeny house.  I sometimes hypermile my heating bill by using a small ceramic space heater in the bedroom and dialing back the thermostat to 62 at night.  Then I have Alexa kick the stat back to 70 at about 8am so my morning pee has better aim.  (hard to hit the bowl when you're shivering)
z31maniac
z31maniac MegaDork
11/16/18 7:51 a.m.
Good looking house.
Thanks Paul! I literally bought it the day it went on the market.
z31maniac
z31maniac MegaDork
11/16/18 7:59 a.m.
There is airflow in the vents in the 2 bedrooms/offices, I often get up and stand over one to warm up my feet. There is enough flow I can hear it.
I'm starting to suspect that this "wing" of the house has no insulation in the "attic" space above it. I checked on my local electricity providers website and I'm not eligible for any of the testing/energy efficiency stuff because of my salary. So I'm going to give them a call and see if they can at least direct me toward a preferred contractor for the testing.
Unfortunately, on this side of the house, to get insulation up in this spot is going to mean cutting a hole in the ceiling in one of the rooms/closets/hallway, blowing a bunch of insulation up, then resealing the hole, fixing the texture, and repainting. It's not the god awful popcorn ceiling, but when the redid the house, they put the same texture on all the ceilings as they did the walls.
I think the other answer is windows. This house has a lot of them, and as you can see from the picture, all of them are 6' tall outside of the kitchen and 2 bathrooms. I don't want to think about how much it will cost just to do the bay window thing in the dining area, much less the whole house.
ptGWCC4omLNg9oS9ATrKzc3DNb3ZgjDCFo75XdO3HkvijRrDdGrSBRBnL6ZLQ13N
