4 5 6 7 8
AWSX1686 (Forum Supporter)
AWSX1686 (Forum Supporter) UberDork
2/28/24 2:14 p.m.
Commenting to come back and read through later, but what I've seen so far looks awesome!
java230
java230 PowerDork
3/1/24 9:38 a.m.
Not sure anything is getting built today....
Got the two frames up. Got about 24" yesterday, another 4 so far over night.... I think the trailer is gonna get abandoned here 😂
Wife was having fun!
java230
java230 PowerDork
3/4/24 12:17 p.m.
About an hour and a half of work. Had to adjust post bases and plumb everything up. Got rafters on. Need more Tico nails. I think they are in the other cabin..... I post holed over there once already....
Roof is on. Need more Tico nails... But it's 90% done and you can stand under it.
SV reX
SV reX MegaDork
3/4/24 12:28 p.m.
In reply to java230 :
Super glad to hear you are using actual Teco nails. Just took apart a floor that someone had used roofing nails... nope!
java230
java230 PowerDork
3/4/24 2:18 p.m.
In reply to SV reX :
I see it all the time.... There is a reason they are nice and thick.... Much of the cabin has screws in the hangers, but they are at least good quality ones.
java230
java230 PowerDork
3/12/24 2:56 p.m.
Doggo sat in his own chair for a little while
java230
java230 PowerDork
3/21/24 12:10 p.m.
Well I got all the sleds out.... Went for a nice ride. I did a great wheelie on the way home. Into a whoop..... berkeley me. This was maybe 10 mins after it happened.... At least I was on the way home.1000019935.jpg
java230
java230 PowerDork
4/1/24 9:25 a.m.
Been working on the fire shelter. Added a bar/table top. Going to add firewood storage under it.
Holds the Jackery nicely for the fire blow jobber.
Well I got crutches and a boot now. Awesome.
java230
java230 PowerDork
4/11/24 11:45 a.m.
Foot blows. No pain killers do anything. Sitting by the fire in the boot with my foot on a stool....
Pass got a dumping and I can't ski 😭😭😭😭
Anyone have experience with well Points?
This is the area that is always wet. There is standing water there right now.
I was hoping to go in horizontally at the bottom edge of that hill, but I'm not 100% sure it will be low enough to hit the water? Run at a shallow angle down? The idea behind horizontal is it may flow out a bit and not need a pump?
Thoughts?
golfduke
golfduke Dork
4/11/24 12:18 p.m.
I know nothing about horizontal wells... but I was curious- is this thread current now??
golfduke
golfduke Dork
4/11/24 12:18 p.m.
akylekoz
akylekoz UltraDork
4/11/24 12:46 p.m.
Is this in an Artesian well warning area?  My parents had a property that was very difficult to get anyone to dig in, 50/50 chance of making a new stream.
java230
java230 PowerDork
4/12/24 10:32 a.m.
In reply to golfduke :
Almost current!
In reply to akylekoz :
One neighbor has a spring, we have a creek right behind us, but this area is always wet. So I was thinking I may be able to "start" a spring per say.
Digging here does not create new streams, its pretty sandy for the most part.
java230
java230 PowerDork
4/12/24 10:34 a.m.
Supposed to be - 22 tonight.
Good thing the power just went out and smoked us out....
Lots of shoveling
Got down to - 24....
Had to dig the generator out, literally, and it did not want to start that cold. But it did eventually fire up and worked through the night. Power came back about 4am. One down side to the pellet stove... It needs power.
java230
java230 PowerDork
4/15/24 1:16 p.m.
Another 16" of fresh stuff.
UPS is tucked into the corner by the recycle bins. According to the data sheet it should run the stove (without the ignitor) for a couple hours. But in reality I assume it's much less. All I need is a shut down cycle tho!
Well it's melting out in a freaking hurry. Low snow year. Fire season may suck.... A lot.
Dragged a ton of brush out before the maples grow in. It's all stacked nicely for chipping.
java230
java230 PowerDork
4/16/24 11:10 a.m.
So glad I got the big chipper!!
java230
java230 PowerDork
4/18/24 2:09 p.m.
Lots of little misc things this past weekend. (and we are now current!)
I reminded myself how to use cad and designed and printed a thing! It adapts a computer fan to a 4" duct so I can add a bit of venting to the container. My 4 1/8" hole saw was dull AF, so it doesn't fit quite right yet.... But Ill fix that next weekend.
Solar panel is hooked directly to the fan (24VDC fan) any time sun is up, fan is on.
Wheelchair is super handy! I ahve so much wood to cut and move.....
That is one bed full. I have a lot more......
Borrowed the neighbors tractor and finished spreading all the RR ballast.
Assembled some new chairs for the deck.
Moved BBQ over, it constantly greased up the window....
Changed the air filter on the chipper.
And it barely fits..... I need to do some organizing.
java230
java230 PowerDork
4/23/24 10:39 a.m.
Lots of chip piles made. Trimmed and cleared a lot more this last weekend.
Finished another 30ft of ski fence
Used my oba to finish nailing off the fire gazebo
Pulled stump out of drainage swale
And if you see a theme here, this thing is HANDY.
Douched the Contrainer and slid everything back so I have parking room.
Finished the fan up. Printed another adapter just a little bigger and done.
Good weekend!
4/23/24 11:09 a.m.
outstanding!  i'll never do this, but i do enjoy the thread.
container needs more semi-gloss white paint inside.  i'd paint the floor too, it'll really help with the light inside.
java230
java230 PowerDork
4/23/24 11:20 a.m.
Very true, did not even think about that. The lights get picked up by the camera much more then they are in reality. They are just little battery motion lights. But its way better than it was! The shelving is so nice to finally have rather than just piling everything up.
java230
java230 PowerDork
5/3/24 10:18 a.m.
Hillbilly hot tub incoming!
Radiator for a heat exchanger if I can get the nipples out.
11GTCS
11GTCS SuperDork
5/3/24 1:33 p.m.
You'll need an internal spud wrench to get those out.    Watch your toes around that radiator! laugh
java230
java230 PowerDork
5/3/24 3:27 p.m.
In reply to 11GTCS :
I'm a little behind again.... Lucky me, they were brass! Had to cut the union nut off, but a monkey wrench and a rubber mallet broke them free easy!
It is stupid heavy. Prob 70lbs, which seems like a lot for as small as it is.
11GTCS
11GTCS SuperDork
5/3/24 6:00 p.m.
Glad they cooperated (Lucky! LOL)   Some of the old timers used a type of pipe thread compound that cured hard with heat on steam systems and it's a nightmare to break free  The brass nipples were your friend in this case.   That's going to make an amazing heat exchanger for your redneck hot tub.  Carry on!
java230
java230 PowerDork
5/3/24 10:35 p.m.
It's working!
4 5 6 7 8
6Fv26N9mtTNgB8aCoJqUZAY0yE0F7Qm59qaM64cgYDZxTyj8Qp5BpfdHNZS9rdB7
