ThePhranc
ThePhranc Reader
10/7/11 9:42 p.m.
Swapped the in and out lines on my remote oil filter system and siezed the motor up. Lots of go fast/ turn fast/ stop fast goodies on it. Contemplating another Mazda Mx-6 or a new motor. There isn't a whole of option for a motor swap.
I have never been disgusted with my self as I am now. This was a mistake that never should have happened.
Grizz
Grizz HalfDork
10/7/11 9:46 p.m.
That sucks, if you decide nother car:
http://baltimore.craigslist.org/cto/2599343802.html
http://baltimore.craigslist.org/cto/2633129371.html
Both are pretty close and relatively cheap.
MG_Bryan
MG_Bryan Reader
10/7/11 9:48 p.m.
E36 M3 happens. Everyone berkeleys up every now and again. Any junkyard in your area with a long block worth buying and swapping. Good luck with whichever route you take; don't beat yourself up over it
ThePhranc
ThePhranc Reader
10/7/11 9:59 p.m.
Lots of junk yard motors around. If I go the motor route it may take over a year to put it in. I don't need it as a DD so I would take my time and rebuild it.
So many options to look over. I really love the platform but I might start looking into something else all together.
11110000
11110000 Reader
10/8/11 6:55 a.m.
I'll offer some sympathy - it's not your fault. The system should have been designed with different fittings, different colors, something inherent to differentiate between in and out. It's called mistake-proofing, because we all have momentary lapses in concentration.
Maroon92
Maroon92 SuperDork
10/8/11 7:00 a.m.
do one of those KLZE swaps with a big turbo...
mndsm
mndsm SuperDork
10/8/11 7:51 a.m.
Boosted KLZE. you know you want to.
92CelicaHalfTrac
92CelicaHalfTrac SuperDork
10/8/11 8:43 a.m.
Bewsted KLZE is teh dumbz.
Boosted KLG4 is where it's at.
Wanna sell me some go-fast parts?
iceracer
iceracer SuperDork
10/8/11 9:43 a.m.
Depends on when it siezed. If it was just idling and stopped, then maybe a new set of bearings will fix it. Now it were at high rpm and there are new ventilation holes in the block. that is another story. Is it worth pulling the pan and taking a look.
integraguy
integraguy SuperDork
10/8/11 9:45 a.m.
That Baltimore MX looks pretty good, wish I live A LOT closer.
ThePhranc
ThePhranc Reader
10/8/11 10:45 a.m.
KLG4 is the way to go. It seized doing about 25 went chunk chunk seize. The tires locked up and I was half way out into a major intersection. It doesn't even turn over.
After conferring with the house boss I'll just be parting the car out. Her exact words were " Why do front wheel drive again when you can get a real car?"
92CelicaHalfTrac
10/8/11 11:11 a.m.
Let me know what go fast goodies you have. I think i have pretty much everything you can get, but you never know.
ThePhranc
ThePhranc Reader
10/8/11 11:50 a.m.
92CelicaHalfTrac wrote: Let me know what go fast goodies you have. I think i have pretty much everything you can get, but you never know.
Headers, MSD 6Al dig never used), ported KLG4 intake, KL47 TB, most of my parts are suspension and brakes. I have a MS6 brake upgrade SS braided lines( 7 lines all together i had one line go bad and had to buy a whole set), megan rear lateral (never installed with King6 sway bar adapters)and trailing arms, tociko blues and ksport springs with new mounts and bearings , rr motor mounts inserts ( rear hasnt been put in yet, front has less than 500 miles) corksport bronzeoil shifter bushings ( shifter side never used because i did the civic sts, trans side less than 500 miles), Drag DR-38/blue stripe 17" x 8" 35 or 37 offset rims with worn out tires ( was going to by some nittos this weekend) rear strut bar, 626 rear sway.
Other stuff I have is brand new head gaskets, head bolts and valve cover gaskets. blue led modded gauge cluster. relatively new non-abs master cylinder and brake booster, LCAs with less than 500 miles, brand new in box timing belt and tensionor kit, 2 new slim rad fans with less than 300 miles, brake portioning valve, rad fan tremo control switch. Also have a new remote dual oil filter kit with less than 20 min run time :)
The car handled really good and stopped better than most vettes.
z31maniac
z31maniac SuperDork
10/8/11 11:55 a.m.
11110000 wrote: I'll offer some sympathy - it's not your fault. The system should have been designed with different fittings, different colors, something inherent to differentiate between in and out. It's called mistake-proofing, because we all have momentary lapses in concentration.
Not to make OP feel worse, but HE could have done exactly what you are talking about.
Blue painters tape and a sharpie.
I've got each in the garage for that exact purpose.
Sorry to hear about the mistake!
mike
mike Reader
10/8/11 2:45 p.m.
ThePhranc wrote: Swapped the in and out lines on my remote oil filter system and siezed the motor up. Lots of go fast/ turn fast/ stop fast goodies on it. Contemplating another Mazda Mx-6 or a new motor. There isn't a whole of option for a motor swap. I have never been disgusted with my self as I am now. This was a mistake that never should have happened.
Kudos to you for owning up to the mistake. There's not enough of that in the world today.
ultraclyde
ultraclyde HalfDork
10/8/11 3:30 p.m.
ThePhranc wrote: KLG4 is the way to go. It seized doing about 25 went chunk chunk seize. The tires locked up and I was half way out into a major intersection. It doesn't even turn over. After conferring with the house boss I'll just be parting the car out. Her exact words were " Why do front wheel drive again when you can get a real car?"
Kudos! She sounds like a wise woman and an asset to your household.
Condolences about the car. We've all been there on some scale. Try to look at it as an opportunity if you can. Strong drink may help that.
92CelicaHalfTrac
10/8/11 7:05 p.m.
Headers, MSD 6Al dig never used), ported KLG4 intake, KL47 TB, most of my parts are suspension and brakes. I have a MS6 brake upgrade SS braided lines( 7 lines all together i had one line go bad and had to buy a whole set), megan rear lateral (never installed with King6 sway bar adapters)and trailing arms, tociko blues and ksport springs with new mounts and bearings , rr motor mounts inserts ( rear hasnt been put in yet, front has less than 500 miles) corksport bronzeoil shifter bushings ( shifter side never used because i did the civic sts, trans side less than 500 miles), Drag DR-38/blue stripe 17" x 8" 35 or 37 offset rims with worn out tires ( was going to by some nittos this weekend) rear strut bar, 626 rear sway. Other stuff I have is brand new head gaskets, head bolts and valve cover gaskets. blue led modded gauge cluster. relatively new non-abs master cylinder and brake booster, LCAs with less than 500 miles, brand new in box timing belt and tensionor kit, 2 new slim rad fans with less than 300 miles, brake portioning valve, rad fan tremo control switch. Also have a new remote dual oil filter kit with less than 20 min run time :) The car handled really good and stopped better than most vettes.
Can you email me what you want for the 6AL, dual filter kit, MS6 brake upgrade to start? Might want more, have to take stock of what i've got.
What headers were they?
I'll see my email on Monday, we can talk then if you send me one.
ThePhranc
ThePhranc Reader
10/8/11 7:59 p.m.
Can you email me what you want for the 6AL, dual filter kit, MS6 brake upgrade to start? Might want more, have to take stock of what i've got. What headers were they? I'll see my email on Monday, we can talk then if you send me one.
PM sent.
mad_machine
mad_machine SuperDork
10/9/11 8:12 a.m.
It's a sickening feeling isn't it? in my 24 years of driving I have killed one car. Even the one I totalled, kept running long enough to get me home (with no coolent from a holed radiator) That one, it left me stranded on the side of the road.. was the worst feeling yet.
bluesideup
bluesideup Reader
10/9/11 10:35 a.m.
Uh not to make you feel worse but I've never installed one of those kits. Any tips to not making the same mistake?
If it makes you feel better I toasted wheel bearings, an LSD, and a viscous transfer case by adjusting my parking brake too tight eons ago.
ThePhranc
ThePhranc Reader
10/9/11 11:07 a.m.
To not make the same mistake just take you time and double check. I had it all installed once and it worked fine with the exception of a pin hole manufacturing defect. I sent the first one back and installed the second in under 5 min because it was all pre-done. When I put the new one one I rushed and was over confident. Though I grabbed the right house for the right port. I was wrong.
exyAvRz0HazJVVEOo0G5u2zin3qxygJB7LILKmBwCS7sk3fW7LKalDQD0HUy8hFS
