Dusterbd13
Dusterbd13 UltimaDork
6/14/17 11:38 a.m.
ProDarwin wrote:
KyAllroad wrote: The problem with a knee wall is that opening the door a foot or two will open up a big gap at the top.
Didn't think of that, good point.
Neither did i.
And the door wall is south facing. Directly in the sun all day....
ProDarwin
ProDarwin PowerDork
6/14/17 12:20 p.m.
Try insulating the doors as well?
Dusterbd13
6/14/17 12:23 p.m.
Doors are already insulated. Also have very minimal amount of air leaks around them.
Dusterbd13
6/14/17 8:28 p.m.
Had another idea about the vent.
Why couldn't i t into the dryer vent that is metal tube run along the ceiling in the shop? Use a y pipe, and no structure changes, door cutting, etc.
There has to be a reason its not a good idea....
ProDarwin
ProDarwin PowerDork
6/14/17 8:59 p.m.
Dusterbd13 wrote: Had another idea about the vent. Why couldn't i t into the dryer vent that is metal tube run along the ceiling in the shop? Use a y pipe, and no structure changes, door cutting, etc. There has to be a reason its not a good idea....
So your dryer doesn't push lint down into your cooler?
Dusterbd13
6/14/17 9:13 p.m.
Hmm.....
Lint. It would find a way to backfeed through the y pipe, wouldn't it.....
old_
old_ HalfDork
6/14/17 10:03 p.m.
https://www.amazon.com/Fantech-9800000-RSK-4-Backdraft-Damper/dp/B000CDAFE6
Dusterbd13 wrote:
Hmm.....
curtis73
curtis73 PowerDork
6/14/17 11:28 p.m.
pinchvalve wrote: I wonder if there is a GRM solution here? If you pulled the A/C unit from a city bus or a roof unit from a large RV could you make it work?
I knew my ears were tingling for a reason. You knew I could think up something with duct tape and a used small block, right?
I can't come up with anything better than a cheap, mass-produced A/C unit. Cheap, effective, reliable.
But, a small turbine-powered compressor through about 10 recycled fridge condensers outside and the evap from three RV rooftop units should do the trick.
Dusterbd13
6/15/17 6:18 a.m.
old_ wrote: https://www.amazon.com/Fantech-9800000-RSK-4-Backdraft-Damper/dp/B000CDAFE6
Dusterbd13 wrote: Hmm..... Lint. It would find a way to backfeed through the y pipe, wouldn't it.....
This seems perfect. Although I wonder if the ac unit would see it as a flow restriction.
XBynbQYi31UINdIIInEBsK1afBJjxNV5AsF4VJYJVoAG8pKUKUIO5OcbDV25OXjd
