2 3 4
Sparkydog
Sparkydog HalfDork
7/28/20 12:19 p.m.
In reply to Mezzanine :
white_fly
white_fly HalfDork
7/30/20 10:55 a.m.
The oxygen lance is a very, very interesting idea that I did not know about, but it doesn't look like it would be faster or cheaper than an emergency saw.
californiamilleghia
californiamilleghia Dork
7/30/20 11:17 a.m.
do the balls stay in their cages so they do not touch each other ?
so if you cut the bearing in half  can you pull the cage out with the balls ?
I just do not see that they would built it like an old bike rim and just stuffing in the correct number of balls so they wear on each other......
white_fly
white_fly HalfDork
8/5/20 3:09 p.m.
In reply to californiamilleghia :
There are no cages. The bearing races encompass nearly the whole ball so there are just little spacers between the balls.
Stampie (FS)
Stampie (FS) MegaDork
8/5/20 4:34 p.m.
You could do some cool Mission Impossible stuff and freeze the outer race with liquid nitrogen then just tap it with a hammer and it'll fall apart.  At least that's how it works in the movies.
03Panther
03Panther HalfDork
8/5/20 5:46 p.m.
Thanks for the pictures ( with a start towards "circles and arrows and paragraphs..."
 I was having trouble figuring the assembly.
Wish I was still travelin' ; like stampie, I'd be all over tearing them apart!
slefain
slefain PowerDork
10/6/20 2:40 p.m.
So, white_fly did you get your balls?
Mr_Asa
Mr_Asa SuperDork
10/6/20 3:12 p.m.
In reply to slefain :
I think I saw a mention of him forging something in another thread, so maybe?
Mr_Asa
Mr_Asa UltimaDork
11/20/22 8:28 a.m.
Because I saw him in the Orlando get together thread, I wanted to bump this.
white_fly, how did everything work out?
white_fly
white_fly HalfDork
11/20/22 10:10 a.m.
Oh, boy, I really left this hanging. I haven't found a source for a big blade bearing since the initial one that I wasn't able to cut up quickly enough. What I have found were a bunch of smaller (50-100lbs) high speed shaft bearings. I shipped over 2000lbs of steel from Idaho to Tampa in a 275 gallon tote this year. A simple angle grinder with slicing discs has been the best thing to cut those up.
If I did get access to a big one, I think an emergency saw with a friction disc would do the trick, but I still don't know.
2 3 4
CkealpZx723oOsxWb2pdyDyXXb8YDlq8lZHGGKrsCOstIYMi8ylqZaUDonyo9vsO
