¯\_(ツ)_/¯
¯\_(ツ)_/¯ PowerDork
11/6/19 9:51 a.m.
I have a plan at this point that will be put into action when I do some other interior stuff in the shop this winter- we pulled up a lot of carpeting in the house and I saved all of the foam underlayment, so I'll line the walls in the "music area" with that and do another layer of drywall or similar over that, possibly with some carpets hung on it as well.  The shop also has a new roof with more insulation now, which seems to cut the exterior noise a bit.  The new music area location will also be further from any windows.
No complaints from the neighbors lately but more quieting can't hurt.
dean1484
dean1484 MegaDork
11/6/19 7:05 p.m.
Just be mindful of the fire hazard potentially created by hanging/covering walls and things with materials that burn well. The station nightclub fire in RI is a recent example and for us older people that know history the coconut grove fire. Both changed the fire codes.
triumph7
triumph7 Reader
11/7/19 8:33 a.m.
A lot of recording studios use walls built using two sets of offset studs so that the drywall on one side is not physically connected to the drywall on the other side.  That way sound hits one side and is absorbed by fiberglass insulation but not transmitted through the wall.
Antony_Roberts
Antony_Roberts New Spammer
1/30/20 4:51 p.m.
In reply to ¯\_(ツ)_/¯ :
You can play on electronic drums, and control your sound.  But if that doesn't suit you, You need a drum shield for top level sound control and this best way to solve the issue with your neighbors . It's not too expensive, But it really works!
Read [canoe] article, It contains all got you need. Good Luck)
VccTfauZP0iMn8XZsk3PXcgRxR7z1oNNx0JgnUSuFgGllyfg9op3rwPfr0TScjyl
