Stampie
Stampie UltimaDork
3/27/20 12:13 p.m.
I need NPSC and I have the tap for it.  Can I buy a NPT female fitting and just cut the threads using my NPSC die?
Edit.  Last word should have been tap not die.
fanfoy
fanfoy SuperDork
3/27/20 12:26 p.m.
What size and what material?
Generally yes, but if the material is too strong (steel) or the size too big (above 1"), you'll break your tap.
Stampie
Stampie UltimaDork
3/27/20 12:29 p.m.
It's stainless and the size is 1 inch 11.5 tpi.
fanfoy
fanfoy SuperDork
3/27/20 1:07 p.m.
In reply to Stampie :
That's risky. Lube the hell out of it and be ready to sacrifice that tap
Stampie
Stampie UltimaDork
3/27/20 1:55 p.m.
In reply to fanfoy :
I've been following that advice most of my life.
Stampie (Forum Supporter)
Stampie (Forum Supporter) UltimaDork
4/1/20 8:47 p.m.
Don't you hate when you google something and find the same question asked before but never see the final result?  Me too!  So I got the 1 inch NPT coupling in and tried my 1 inch NPSC tap.  It was so tight I didn't even want to try and get it started.  That said I put the 1 inch NPSC part into the coupling and it seems it'll seal up enough so good to go.  I'll follow up if it's not water tight once done.
yJL2Zbg1pftUkkE5RzpUmTddfnZC39jcQwn64bS226OErUfoo5AIF6TWtR0sJ6mN
