RealMiniDriver
RealMiniDriver SuperDork
10/18/12 11:18 a.m.
I work in a machine shop, and occasionally, we need to temporarily fill a cavity (or cavities). My boss said that years ago, we had some green plastic-y stuff that could be melted into the cavity, then melted out when done working on the part(s). My Google-fu is weak and I can't find this stuff.
If this forum can find horse blood, surely you guys can find meltable plastic.
1988RedT2
1988RedT2 UltraDork
10/18/12 11:21 a.m.
Green plastic? Lead is much more appealing!
Ranger50
Ranger50 UltraDork
10/18/12 11:27 a.m.
I'm just wondering if it is a Devcon derivative. Just uses a solvent to soften after use making removal possible.
lastsnare
lastsnare New Reader
10/18/12 11:36 a.m.
if it didn't need to withstand much heat (while you were using it for temporary filling purposes), could you use something like paraffin wax ?
(I'm not sure if that would leave a residue or not, it's been a long time since I messed around with it). Not the same as plastic of course, but just tossing out the idea if no better solution was found. It might be completely wrong for what you need it to do :)
MadScientistMatt
MadScientistMatt SuperDork
10/18/12 11:37 a.m.
You may be looking for Babbitt putty; see the bottom of this page:
http://www.mcmaster.com/#metal-casting-alloys/=jrxr6k
rotard
rotard Dork
10/18/12 11:39 a.m.
There are a variety of plastics that would meet your needs. It really depends on the temperatures involved.
spitfirebill
spitfirebill UltraDork
10/18/12 11:47 a.m.
If something was available years ago and was good, it probably isn't allowed now.
RealMiniDriver
10/18/12 11:49 a.m.
Mad Scientist Matt may be on to something. Thanks!
RealMiniDriver
10/18/12 11:50 a.m.
spitfirebill wrote: If something was available years ago and was good, it probably isn't allowed now.
No E36 M3.
4cylndrfury
4cylndrfury UltimaDork
10/18/12 12:02 p.m.
Friendly Plastic is a thermoset plastic that becomes very rigid when cool, and has almost 0 net shrink. It can be re-heated to re-soften as many times as you like.
jamscal
jamscal Dork
10/18/12 9:05 p.m.
The first products in the mcmaster link are what you're looking for... Low Melting Temperature Casting Alloys
Most melt under the boiling point of water,,,and that's how you remove them.
Also I think it was called woods metal.
-James
kCai3KMU68wMzU6hPpS3IyjXQL0Z0jCFmozxw3JnW5MuGKUG1CUyDa6xKFz9eP3G
