corytate
corytate UltraDork
4/18/14 9:14 p.m.
Hi,
got rally armor basics for the genesis and the front is fairly straightforward: The screws and clips for the wheel well liner are placed such that I can just reuse them.
For the rear, however, I can only really utilize one screw, the other one is too high and the inner screw is too far inboard to work.
and the stupid wheel well liner is like a fabric material, so I don't think screwing directly into it would hold worth a damn.
I'll take pictures tomorrow if I still can't figure something out, but are there any alternative mounting methods I may be able to use? super strong durable double sided tape? idk...
please, help me brainstorm!?
wae
wae HalfDork
4/19/14 8:14 a.m.
Could you put a hole in the liner and use some large fender washers and a nut and bolt?
Jerry
Jerry Dork
4/19/14 8:23 a.m.
I bought Rallyarmor UR flaps for the Abarth, they came with brackets that matched the holes in the fender liner with the exception of one hole I had to drill in the plastic on the rear. Guessing the basics aren't as engineered?
The washers/nut/bolt idea sounds like how the RokBlokz I put on the Subaru worked.
corytate
corytate UltraDork
4/19/14 1:39 p.m.
Yeah the basics are just universal, noone makes any that fit the car sadly.
Ill look into the washer idea, im thinking itll work. Thanks!
warpedredneck
warpedredneck Reader
4/20/14 8:32 a.m.
could you use a couple of chain links and 'hang" them?
corytate
corytate UltraDork
4/20/14 10:26 a.m.
In reply to warpedredneck:
Idk about that on a rwd sports car. I want it flush mounted to the wheel well also
corytate
corytate UltraDork
4/21/14 7:52 p.m.
got it!
Yx8Gwpl1oYiIluHhmbKgrrSoI5o3FxBC59L3yUfbjnL4S2cIy1Zdz0NZxbnrREEf
