1988RedT2
1988RedT2 PowerDork
1/23/14 4:12 p.m.
I read a few "how-to's" and watched some worthless youtube videos, but this guy has got the answer!
http://boginjr.com/electronics/lv/atx-mod/
My interest in amateur radio got me looking for a cheapo 13.8 VDC power supply. Having more than a handful of old computers laying around, my mind naturally considered the PSU out of a desktop computer. There are plenty of write-ups which suggest that a load on the 5-volt output and an adjustment of a potentiometer will give you a useful supply. However, none of the supplies I looked at had any such potentiometer.
The author of the article in the above link however, documents a procedure by which a potentiometer may be added to the regulator IC in the PSU and allow full adjustment of the output voltage from 5 to 15 VDC or so. Parts are readily available from Radio Shack or an online business such as Parts Express.
After making a nifty paperweight out of my first attempt (make sure you've got all the wires properly insulated and secured before you power up your project!) I got my next effort to perform flawlessly!
Modifying and repurposing an old computer power supply for use with a 2-meter mobile radio--what could be more grassroots than that?
Hope someone finds this useful, or at least interesting!
RossD
RossD PowerDork
1/23/14 4:22 p.m.
Neat. Do you need a precisely controlled voltage independent of current draw for amateur radio?
1988RedT2
1988RedT2 PowerDork
1/23/14 4:48 p.m.
RossD wrote: Neat. Do you need a precisely controlled voltage independent of current draw for amateur radio?
Kenwood recommends 13.8 VDC at a minimum of 14 Amps for my radio. That, or wire it into a car's electrical system.
Strizzo
Strizzo UberDork
1/23/14 6:29 p.m.
14 amps? You putting out 200w?
1988RedT2
1988RedT2 PowerDork
1/23/14 7:22 p.m.
Naw. High power setting is like 55 watts. I work the repeater with the low power setting which is like 20 watts. I've got a panel meter between the PSU and the radio for Volts and Amps so I can make sure the supply is doing okay. Voltage does not drop noticeably on transmit and it pulls 6 Amps on low power setting. Haven't tried it on high power yet...
dculberson
dculberson UltraDork
1/24/14 9:23 a.m.
Awesome! Computer power supplies are also great to use for bench work, 5v and 12v are very usable when testing / working on things. Most car stuff (radios, etc) runs fine on 11 - 14v so 12v is right there. I love the DIY adjustable regulator.
I have a "real" bench-top adjustable power supply from back in my tech days but this is a cheaper way to get it. And everyone that works on electronics and car things should have an adjustable power supply.
oldopelguy
oldopelguy SuperDork
1/24/14 5:11 p.m.
I use an old AT computer power supply for charging phones and stuff. The 12v is wired to o couple of lighter plugs in the housing and the 5v is wired to a USB hub sitting on top.
DrBoost
DrBoost PowerDork
1/24/14 5:28 p.m.
I'm looking for a 12V power supply, 5 amps is more is great. If you have one, lemme know.
WavlVtYA3QEOPfxQhytkxN0ckNgPHkGdi1zNsdWGi4EbrRWUkzTwfIOIA3VtvHGj
