EvanR
EvanR Dork
1/30/16 2:38 a.m.
I've made a few small brackets out of 6061 aluminum angle. I want to rattle can them to a pretty, durable finish.
Do I need to scuff to get good adhesion? What grit?
Am I compelled to prime before painting?
Thanks.
XLR99
XLR99 HalfDork
1/30/16 5:59 a.m.
Sand with maybe 320 grit, self etching primer, then paint?
That would be my novice way to do it.
1/30/16 7:13 a.m.
I've had very good luck over the years with a House of Kolor product called Adhereto, it a very thin, watery primer that sticks anything to anything.
Dan
Dr. Hess
Dr. Hess MegaDork
1/30/16 7:41 a.m.
I have had good results with Rustoleum. Just scuff it up good, wipe it down with mineral spirits first, then hit with the Rustoleum.
1988RedT2
1988RedT2 PowerDork
1/30/16 7:49 a.m.
If the surface is clean, you should be fine. Do like the good doc says.
ncjay
ncjay Dork
1/30/16 8:29 a.m.
I usually just scotchbrite the aluminum before primer and paint.
DaveEstey
DaveEstey PowerDork
1/30/16 2:32 p.m.
scotchbrite, degrease, prime, paint.
motomoron
motomoron SuperDork
1/30/16 2:51 p.m.
Vracer111
Vracer111 Reader
1/30/16 8:46 p.m.
Light sanding, 0000 steel wool, painting with Krylon Fusion, and then clear coating worked fine for my custom mirror mounting plates made from 1/8" 6061 sheet:
Lesley
Lesley PowerDork
2/2/16 9:37 a.m.
^^ What he said. My build car is in an aviation business (lucky me, talk about inspiring) and this is the process they use.
l1IYUIeC1KnLZ8u5GcaaRQ8bFVZle1DdRNPIIA1hlBhvI0QpCaOB0J2YafiGoRtW
