rustybugkiller
rustybugkiller HalfDork
4/26/20 1:07 p.m.
Surprisingly, the bolts are still secure. The bolts are 13 inches from the back wall so a standard toilet will fit. However , The drain pipe is not completely level with the floor. It appears there was a half inch lip of the pipe protruding from the floor which has now had pieces of it broken off.   I'm assuming I can't put a wax ring over top of this or can I? Or do I install a plastic fitting that goes inside the pipe and has been secured to the floor?
I'd appreciate any help? Thanks!
preach
preach Reader
4/26/20 2:29 p.m.
I had a similar issue in our back apartment and used one of the plastic inserts.
SVreX (Forum Supporter)
SVreX (Forum Supporter) MegaDork
4/26/20 5:31 p.m.
The better wax rings have rubber collars on the bottom side.  I'd grind off the rough cast iron edges.  Then I'd use one of these and call it a day:
Assuming there is not damage to the pipe lower than that.  I wouldn't leave raw concrete exposed to sewage.  It absorbs.
3N3HDYjex5hB0uz7M392jtHapNHsBEV7y8kHGBXK56MZBt6tC7T1KGORC8Mxy663
