joey48442
joey48442 UberDork
12/22/12 10:12 a.m.
Is it possible to use a small two or four channel amp with a line in to connect to my iPhone? Maybe a headphones to RCA type plug? I never listen to the radio, it's all pandora or streaming NPR.
Thanks,
Joey
Zomby Woof
Zomby Woof UberDork
12/22/12 10:27 a.m.
Yes. I use a small T amp in my Swift GT in pursuit of lightness. All the amp wants is a signal, and a headphone jack to RCA cable will work. It's what I use
joey48442
joey48442 UberDork
12/22/12 10:49 a.m.
Zomby Woof wrote: Yes. I use a small T amp in my Swift GT in pursuit of lightness. All the amp wants is a signal, and a headphone jack to RCA cable will work. It's what I use
Cool thanks!
My new to me YJ has a weird stereo hole and I thought in the pursuit of simplicity (the YJ is nothing if not simple) I might try this.
Joey
joey48442
joey48442 UberDork
12/22/12 10:56 a.m.
Ok, so now my next question, is there a fader function on a 4 channel amp? Obviously the iphone has no control for fader, as its only stereo, correct?
Joey
belteshazzar
belteshazzar UberDork
12/22/12 11:02 a.m.
typicallly
sobe_death
sobe_death HalfDork
12/22/12 11:02 a.m.
In reply to joey48442:
Same way you'd calibrate the gain levels. You won't have the dynamic function, so it will be 'set it and forget it'.
Knurled
Knurled SuperDork
12/22/12 11:34 a.m.
I wonder if the joystick balance/fade from an 80's Japanese car would work to that end.
I know for certain that the '84-85 RX-7 mounted them pre-amp.
joey48442
joey48442 UberDork
12/22/12 12:27 p.m.
http://www.newegg.com/Product/Product.aspx?Item=9SIA1PC0G56107
How about something like this? I always thought pyle was, you know, a pile, but is there something like this? There is even a model that ties into the ipod style 30 pin connector.
Joey
EvanB
EvanB PowerDork
12/22/12 12:45 p.m.
That is basically what I have in my Miata. Just a small 2-channel amp that I plug my ipod into and it goes to the two speakers. It isn't the best sounding but good enough.
Zomby Woof
Zomby Woof UberDork
12/22/12 1:04 p.m.
This the one I use
http://www.ebay.ca/itm/New-Lepai-Class-T-Hi-Fi-Audio-Amplifier-Tripath-LP-2020A-Amp-20WX2-Stereo-Amp-/370716819993?pt=US_Home_Audio_Amplifiers_Preamps&hash=item565071c219
12/22/12 2:03 p.m.
I was planning on doing this on a couple of my cars where I either don't want a visible modern stereo or I don't need anything else. You can find some that will also power/charge the iPod, they tend to be aimed at ATVs. I'm thinking I'll just get a real amp from Crutchfield.
MattGent
MattGent New Reader
12/22/12 5:13 p.m.
Many boats are set up this way. The amp can be installed somewhere dry, and the face units always crap out.
You'll find lots of options in marine amps.
Zomby Woof
Zomby Woof UberDork
12/22/12 6:52 p.m.
I went the way I did because it gave me volume, bass and treble. If you have 4 speakers, you could use a splitter cable and double up on the amps.
moparman76_69
moparman76_69 HalfDork
12/22/12 7:13 p.m.
https://www.youtube.com/watch?v=u-ALYArl5S4
alex
alex UltraDork
12/22/12 9:53 p.m.
Any chance these things are available with USB to power an Android phone while in use? I've been meaning to do this with my truck forever. (I refuse to install an aftermarket stereo. No matter how crappy they are in reality, they look like broken window magnets to me.)
sobe_death
sobe_death HalfDork
12/23/12 3:41 a.m.
In reply to alex:
You can get 12v accesory to USB converters on Ebay all day long. They pretty much fit right inside the 12v accessory outlet. It's not unheard of to take them apart and hard wire them into a spare hole in the dash...
Joey, If you are going for cheap amps, I would much rather use the one that Zomby Woof posted than anything made by Pyle. I have yet to come across a T-amp that was a bad buy...
joey48442
joey48442 UberDork
12/23/12 7:30 a.m.
sobe_death wrote: In reply to alex: You can get 12v accesory to USB converters on Ebay all day long. They pretty much fit right inside the 12v accessory outlet. It's not unheard of to take them apart and hard wire them into a spare hole in the dash... Joey, If you are going for cheap amps, I would much rather use the one that Zomby Woof posted than anything made by Pyle. I have yet to come across a T-amp that was a bad buy...
I looked up t amp, but couldn't find much. Is that a brand?
Joey
92CelicaHalfTrac
92CelicaHalfTrac MegaDork
12/23/12 9:41 a.m.
T amps are a kind of amp. Also called "chip amps." It's a "class t" amp. Digital instead of analog.
Zomby Woof
Zomby Woof UberDork
12/23/12 10:15 a.m.
http://www.parts-express.com/cat/amplifiers/106?kg=25619|25619
The Lepai amps have worked fine for me.
joey48442
joey48442 UberDork
12/23/12 4:43 p.m.
So, I found an old Alpine two channel amp in the garage from parting out a Miata... It works! Just need to find a place to install it. It sounds pretty decent though. If it doesn't work out, I may buy one of those lepai amps.
Joey
MikeZInZ7wzV6c6kWPZVwLf4mloZ2kzP22L4m2RHprSNB4Vw40yYVwkW699Kp9RB
