Helping with an engine swap in an olds 442. My beard still had some color in it 30 years ago.
In reply to chandler :
It is usually called a break-off screw and should be available from most hardware or electrical supply stores (Lowes, Home Depot, etc). It is usually an 8-32 thread and can be snapped off at various lengths as needed. It can also just be replaced by a regular machine screw of the right thread and length.
Pinot "Greengio" for St. Patty's Day, which the person sitting next to me was drinking last night at Valley CC.
The only successful orchid bloom to ever happen at my house. This guy has been sitting in the kitchen window for years. This year it decided to bloom.
so_slow said:In reply to chandler :
Not the same, it screws through three different openings and helps pull each tight. It's for two piece center caps on an old set of racing dynamic wheels
Streetwiseguy said:
Ford power transfer unit...
Toyota 2GR-FE timing guide pieces, as removed from the oil pan.
Engine made "a loud metallic groaning noise" then stalled on the highway. Cannot rotate with a breaker bar.
*feels smug about preferring timing belts*
GM 1.4 turbo bellhousing pattern. Pulling the engine is the easy way to do a rear main seal.
Ecotec bellhousing pattern.
This O ring seals the main oil gallery to the rear main seal plate on a Honda J series V6 and is the usual cause for an oil leak in the bellhousing. Easiest with engine out etc.
