Chadeux
Chadeux HalfDork
9/16/16 7:08 p.m.
Can you get a Jerico or similar trans with an output that bolts up to say, a Borg Warner 4472 transfer case?
BrokenYugo
BrokenYugo UltimaDork
9/16/16 9:03 p.m.
This is a question I've had but couldn't seem to quickly find an answer on. I'm sure it could be done with a custom output shaft and tail housing/tcase adapter (Jerico might make them for you for an ungodly amount of money?) or just a really long custom tcase adapter if you luck out and the splines match up. Probably not an off the shelf thing unless there exists a divorce kit that fits the BW case (don't know enough about transfer cases to say) and have room to run it divorced.
edit: IIRC the Jerico is Ford Toploader based, might be something there but I'm not sure the toploader saw any truck use.
bentwrench
bentwrench Dork
9/16/16 11:18 p.m.
Advanced Adapters?
novaderrik
novaderrik UltimaDork
9/17/16 2:29 a.m.
divorced transfer case FTW..
just out of curiosity, why are you wanting to hook a Jerico up to a transfer case? i know that Summit hooked one of those transfer cases up to a T56 with a fully custom tailshaft housing when they built their AWD 32 Ford a couple of decades ago so that might be the only way to make it happen..
Chadeux
Chadeux HalfDork
9/17/16 4:26 a.m.
Pipe dream eventual "final form" version of my Bravada. I highly doubt it will ever get to that stage, but I was sitting here wondering what was possible.
I really don't see anything much more than a mild SBC and a shift kit in it's future if I'm honest. The bent E36 wheels are definitely coming off before I drive it again though.
AVp9BZupVcjCwA01Ks6RQRkNCD0rwNHdhdrATHvr3gmEzbfjFE13DpfXqin2Qttm
