carguy123
carguy123 Dork
11/21/09 10:19 p.m.
Does anyone know how to do this?
My son was tinkering with mine and opened a screw that was near the handle and fluid spurted out. Now my jack won't go up but about half of what it would before.
I'm sure there has to be a way to refill it, but it's not obvious to me and I don't want to make matters worse by experimenting.
Also what would I refil it with?
MrJoshua
MrJoshua SuperDork
11/21/09 10:25 p.m.
Their is usually a rubber plug on the side of the cylinder where you add fluid. Search the interweb for bleeding information.
Edit-hydraulic jack oil/fluid.
Woody
Woody SuperDork
11/21/09 10:30 p.m.
You may have to bleed it, too.
carguy123
carguy123 Dork
11/22/09 7:19 a.m.
So the plug is on the cylinder itself and not on the base? I'll go look today. All I've seen are 2 screws on the base right next to where the handle pivots.
mel_horn
mel_horn Dork
11/22/09 8:15 a.m.
Woody wrote: You may have to bleed it, too.
Oh, yes...
Turn the handle like you're letting it down. Pull UP on the saddle a few times. Check the fluid level. Turn the handle like you're raisng it , then put a test load on it and see if it raises normally.
Yd88r6RTUE2UUV8CW5eYTS2KHAOFN1RtfQTKK6HjxzomHcG82lBHla5aV7W44NsQ
