grafmiata
grafmiata SuperDork
11/27/13 9:36 p.m.
logdog wrote: I bought one of these from the local farm and fleet. Its awesome. Very happy with it. http://www.amazon.com/Mr-Heater-MH200CV-000-BTU-Convection/dp/B0000C6E39#immersive_view?1385171756039
Picked one of these up at Home Depot for $140. 200k BTU, and I like the 360° aspect, as opposed to a salamander blasting away only at what it's aimed at.
Hopefully this will get me thru this winter, and then I can come up with my permanent source of heat.
Gonna pick up a two 100lb propane tanks this weekend, and see how it goes.
Ian F
Ian F UltimaDork
11/28/13 6:54 a.m.
Yeah... you'll need some decent sized tanks... A shop I go to used to have one of those - a std 20 lb tank doesn't last a day. Also bear in mind, you may have to have the propane delivered to fill those.
A winter of dealing with it will definitely make you want to come up with a more permanent solution.
paranoid_android74
paranoid_android74 HalfDork
11/28/13 9:35 a.m.
My garage is about 16 by 25. Insulated with 1 1/8 closed cell foam. Left gaps in the ceiling insulation for venting.
I crack the overhead door open about 2" and use a 30k btu kerosene heater. The outside temp was 25 degrees the other day and I was working in the garage with a long sleeve t shirt on and was very comfortable.
But, it does stink- especially at start up and shut down. To help that I open the doors all the way and let it burn for about a half hour, then close it up to heat it. It works pretty good!
Putting something on the floor is a big help too.
rebelgtp
rebelgtp UltraDork
11/28/13 9:47 a.m.
I just have an old barrel stove in my shop.
Brian
Brian UltraDork
11/28/13 9:53 a.m.
http://www.calculator.net/btu-calculator.html
z04rqYS3Q3rM4P8C8VDOqdS29JIfbiXCmlk50Ujhjc5olmUABS8W546h6doTSjGt
