JoeyM
JoeyM UltimaDork
11/4/12 9:50 p.m.
Hey Guys,
I've been looking at enclosed trailers. This one looks OK from the outside ...but what the heck is going on with the interior?
Is something like that durable, or is it some dreadfully constructed thing?
novaderrik
novaderrik UltraDork
11/4/12 10:10 p.m.
i think they all look like that... well, except for the blue paint..
fasted58
fasted58 UberDork
11/4/12 10:42 p.m.
blue paint means 141 mph certified
fastoldfart
fastoldfart New Reader
11/5/12 12:53 a.m.
Isn't that "Blue Angels" blue? Should be good for mach1
N Sperlo
N Sperlo PowerDork
11/5/12 6:18 a.m.
You pass my house creating a sonic boom and I'm-a be pissed.
Toyman01
Toyman01 PowerDork
11/5/12 6:25 a.m.
That's very similar to mine other than the blue paint. Mine's white and the roof is paneled too. The majority of strength is in the framing, the paneling is mostly for looks.
Knurled
Knurled SuperDork
11/5/12 7:23 a.m.
Most trailers I've seen aren't that sturdy. No plywood, just something that looks a lot like plastic-coated drywall.
Jake
Jake HalfDork
11/5/12 8:39 a.m.
Plywood was added by previous owner as better wall paneling, and a better place to hang cabinets, which are what left the unpainted areas.
Maybe they had white and orange cabinets in an awesome Martini/Gulf scheme - more likely there's no accounting for taste and/or they just really liked blue.
Ian F
Ian F PowerDork
11/5/12 9:09 a.m.
That's my guess as well - the raw plywood is where cabinets used to be. Probably now installed in the previous owner's new trailer.
Basil Exposition
Basil Exposition HalfDork
11/5/12 9:14 a.m.
That's pretty typical construction. The more expensive ones are basically built the same way, only might be more finished. My Pace came with plywood on the sides and ceiling that I finished with polyurethane.
More important is to check the axles to make sure they are torsion bar and not leaf spring and can handle the load with plenty of margin.
doc_speeder
doc_speeder Reader
11/5/12 10:05 a.m.
In reply to Basil Exposition:
Hmmmm, I've always preferred leafs on a cargo trailer... Why do you like torsion axles? I've had lots of tire wear problems with them.
81cpcamaro
81cpcamaro HalfDork
11/5/12 10:30 a.m.
Joey, check with some builders of new trailers, sometimes they are close to what some want for their used ones. I was going that way until I ran across a good deal on the Horton Hauler I have now.
I prefer torsion axles myself, the two trailers I have had both had Dexter axles (open and enclosed trailers). No tire wear problems with the enclosed. I did have some on one wheel with the open, but putting new wheel bearings in took care of the wear. Usually wear issues (both torsion and leaf spring) are either bearings or bent axles. I prefer the ride of the torsion axles, smoother than leaf springs IMHO. BTW, I have borrowed leaf spring trailers, so I do have experience with them as well.
ciFs28okGfAmNWbQ4Nv9fMCBIfmpKNybKTetqleKjCFIpkqYV6iD1kRFxKG7F9od
