1988RedT2
1988RedT2 MegaDork
10/19/22 12:43 p.m.
What is the factory wheel lug nut torque spec for a 2019 Mazda CX-9 FWD with 18" wheels?
bobzilla
bobzilla MegaDork
10/19/22 1:06 p.m.
90ft-lbs
EDIT: https://autospecz.com/mazda/cars/2019/cx92.5/torque-specs_front.php
Says 100. 90 would be the AWD
1988RedT2
1988RedT2 MegaDork
10/19/22 1:17 p.m.
In reply to bobzilla :
Thanks!  Generally anything with aluminum wheels I find spec'd at around 95 ft-lbs, so I couldn't miss it by much!
1988RedT2
1988RedT2 MegaDork
11/17/22 1:20 p.m.
What is the most common cause of an old carbureted V-8 gasoline engine, in this case a 350 Chevrolet with a Quadrajet, dieseling--that is, running on for a few seconds after the key is switched off?  Doesn't do it every time, but when it does, it's annoying.
bobzilla
bobzilla MegaDork
11/17/22 1:24 p.m.
timing?
1988RedT2
1988RedT2 MegaDork
3/2/23 11:26 a.m.
For you outboard motor experts:
I own a Johnson J90 TL CTE outboard from 1983.  The lower unit is somewhat rough.  A guy local to me is selling a lower unit from a 1992 90HP that looks amazing.  Will it fit my motor?
Curtis?  Anybody?
1988RedT2
1988RedT2 MegaDork
3/2/23 1:27 p.m.
Curtis?  Anybody?
Well, I've got mine off without too much trouble.  20" shaft appears correct.  As long as they didn't do something goofy like change the spline count, I should be good.  I'm going to take mine with me and do a comparison with his unit before I buy.
1988RedT2
1988RedT2 MegaDork
3/2/23 2:30 p.m.
Okay, I've got the small gearcase, so assuming that's what he has, I'm good.  Same part from 1978-1998.
http://www.sterndrive.info/outboardmotor/v4_90_small_gearcase.html
pinchvalve (Forum Supporter)
3/2/23 2:49 p.m.
Should it burn when I pee?
SV reX
SV reX MegaDork
3/2/23 3:32 p.m.
In reply to pinchvalve (Forum Supporter) :
That might be a question for your sexual partner
yupididit
yupididit UltimaDork
3/2/23 3:39 p.m.
That's normal
1988RedT2
1988RedT2 MegaDork
7/24/23 2:18 p.m.
What lubricant for an electric clothes dryer drum rollers?  Sleeve bearing with fairly close tolerances.  I've used Sil-Glyde, but friction is too high.  Something else?  No lubricant is included with the parts and I find no instructions.
1988RedT2
1988RedT2 MegaDork
7/24/23 2:23 p.m.
Hmm.  Same discussion here.  Maybe no lube is appropriate?  Feels all wrong!
https://diy.stackexchange.com/questions/186085/what-lubricant-if-any-should-be-used-for-clothes-dryer-rollers
jharry3
jharry3 Dork
7/24/23 3:46 p.m.
What is the air speed velocity of an unladen swallow?
aircooled
aircooled MegaDork
7/24/23 4:35 p.m.
In reply to Mr_Asa :
Of note is that the styles of plugs / receptacles are different because they are standardized to the power capabilities of the plug / wiring.
It looks like the drying plug is for a 30 amp outlet and the extension you are using is for a 50 amp outlet (and I will assume it has that plug because the welder can draw that), so be careful, overloading the wiring inside your walls can of course be a very bad thing.
220 Volt Plug Receptacles Configurations - AskmeDIY
aircooled
aircooled MegaDork
7/24/23 4:38 p.m.
In reply to jharry3 :
It's just over 20 mph, but it might differ a bit if it's African or European.  Significantly slower if it's carrying a coconut of course.
gearheadmb
gearheadmb UltraDork
7/24/23 8:26 p.m.
I also think timing.
Edit; I just realized I was answering an eight month old question.
solfly
solfly Dork
7/31/23 8:44 p.m.
Quick is a relative term.
Brett_Murphy (Agent of Chaos)
8/2/23 12:56 p.m.
Situation: Many times I drive on the highway for a while, my Subaru throws a P0457 code. It never happens during city driving.
I've replaced the gas cap and cleaned the filler neck really well. This hasn't solved the issue. What's next?
Dusterbd13-michael
Dusterbd13-michael MegaDork
8/2/23 1:09 p.m.
Metal or asphalt roof and why? Mines 23yo....
1988RedT2
1988RedT2 MegaDork
8/2/23 1:14 p.m.
In reply to Brett_Murphy (Agent of Chaos) :
You have some company, it seems.  Me, I would try to check the purge valve and condition of evap system hoses, but it sounds like a huge PITA.
Javelin
Javelin MegaDork
8/2/23 1:28 p.m.
Sucking the vent hose shut on the tank? I had that happen before.
Peabody
Peabody MegaDork
8/2/23 1:38 p.m.
You don't say what you have now.
I went steel so I'll never have to do it again.
If I recall, the numbers were $4-$5k for shingle, I paid $7k for the steel. It was an easy decision.
Dusterbd13-michael
8/2/23 1:41 p.m.
In reply to Peabody :
Shingles. Honestly all ive ever had. But steel seems like a lifetime solution....
wheelsmithy (Joe-with-an-L)
8/2/23 2:57 p.m.
Former Steel roof manufacturer here. I love metal roofs, but they expand and contract a  lot. This loosens screws over time, and they do eventually leak. If you really want a nuclear option, it is standing seam ($$$).
My roof needs to be replaced. Despite the obvious aesthetic superiority of metal (IMHO), my roof is getting 30 year (3D, 3 tab, same thing) shingles.
qhQViTFoZTay1gmn7yXIpUZbegKXxysrgnGJKYOVlChRprldQi8QqR3gkQPIQFMc
