turboswede
turboswede PowerDork
6/6/12 8:21 a.m.
and I saw this and thought, "well at least the Wife wouldn't complain about the parts in the dishwasher anymore."
musicalannette said: The best way I have seen to flush an engine is remove it from the car, remove all the components(crank, pistons head etc), then take the block into your house, then strip off and take a hot shower with it. Your wife will seriously think you have a mental problem but she will no longer doubt you are having an affair. If you use plenty of washing up liquid with the hot water it helps to remove the old oil, and if there are stubburn oil deposits you need to stop with the water and soak in petrol, even to the extent you block the draing holes for the petrol and allow the petrol to sit in the galleries and break down stuck on deposits for a while, if deposits are still there rinse and repeat. If you use petrol be sure to rinse out the block with more washing up liquid and hot water as if will break down you new oil(the main reason you change your oil every 5000 miles or so). hope this helps. ps if you are helping a mate do this after he drives a pug 205 into 4 feet of water, dont let the neigbours see you as they will think the worst.
stuart in mn
stuart in mn UberDork
6/6/12 8:26 a.m.
That would leave a ring around the bathtub.
BBsGarage
BBsGarage HalfDork
6/6/12 8:42 a.m.
stuart in mn wrote: That would leave a ring around the bathtub.
and your neck after SWMBO finds out.
mad_machine
mad_machine MegaDork
6/6/12 8:48 a.m.
um... I will keep with the vinager bath I soak most of my stuff in
SAGM6KRNlwi8N89rVghZmYCtWN93ANLXsFr4umBjBDN8c5DgNTlhFHMeGa1LkeQe
