ultraclyde
ultraclyde PowerDork
6/27/18 9:29 a.m.
Brian said:
How “Salty” is the water in the saltwater systems? If I get a mouthful of water will it be like having ocean water?
If it is, that might make me more likely to get a pool, lol.
stylngle2003
stylngle2003 Reader
6/27/18 10:11 a.m.
no, imo you can hardly taste it
Toyman01
Toyman01 MegaDork
6/27/18 10:29 a.m.
In reply to Brian :
From what I've read, if you can taste it in pool water, it has too much salt in it.
Pool water should be 3500 parts per million.
Seawater is 35 parts per thousand.
mtn
mtn MegaDork
6/27/18 10:32 a.m.
Toyman01 said:
In reply to Brian :
To translate this, since you didn't use a common denominator:
Pool water is 3.5 parts per 1000; seawater is 35 parts per 1000. 10x more.
MulletTruck
MulletTruck HalfDork
6/27/18 11:28 a.m.
Diving board off the shop roof?
WonkoTheSane
WonkoTheSane Dork
6/27/18 12:20 p.m.
mtn said:
Toyman01 said:
In reply to Brian :
Exactly..  My pool water tastes like that bottled "Smart" water..   There's a hint of salt, but it's not at all close to salt water in the ocean.
spitfirebill
spitfirebill MegaDork
6/27/18 12:52 p.m.
Hey ya'll watch this.
racerdave600
racerdave600 UltraDork
6/27/18 1:05 p.m.
Yeah, you can't taste it.  Its also more skin and eye friendly, and leaves you feeling soft and smooth when you get out.  laugh  Once you have one, you'll never go back to chlorine.  I'd fill my pool in first.
Toyman01
Toyman01 MegaDork
6/29/18 8:28 p.m.
Ingress and egress using the supplies ladder is just about dangerous. Doubly true if you are 6'2" and damn near 300 pounds. Time to solve that situation before I bust my ass. Or worse, my wife does.
I've started construction of a deck off the screened porch.
From this there will be a couple of steps up to a landing level with the top of the pool. Then the supplied ladder will be modified for the climb down into the pool. The plan is to finish this tomorrow.
Toyman01
Toyman01 MegaDork
6/30/18 9:58 p.m.
More of the deck is done.
Son and grandson helping.
New door cut in from the screened porch to the deck.
More to happen tomorrow.
Brian
Brian MegaDork
7/1/18 9:36 a.m.
It’s coming along nice.
nedc
nedc Reader
7/1/18 1:34 p.m.
Looking good. The issue i have with a pool here in SC (I'm about 1.5 hrs. N of you) is, by this time of year, the water has heated up so much you can't really swim comfortably in it. I prefer to swim in 80-84 degree water and right now it is 90+ degrees even with running a fountain all night to try and cool it off.
Toyman01
Toyman01 MegaDork
7/1/18 4:16 p.m.
In reply to nedc :
The water temp is currently 87. Today that actually feels kind of cold when you first get in. I'm pretty sure that by mid August it should be warm enough to cook noodles.
Toyman01
Toyman01 MegaDork
7/1/18 4:27 p.m.
We did a little more work this morning and things are coming together quite nicely.
Some modification of the original ladder was required. It works much better now. The globes are solar floating lights sitting in the sun to charge.
In the pile of stuff that came with SanFord, was a RV canopy I decided to not use. It works perfectly on the deck.
All in it's turning out pretty well I think.
The kids and grandkids are having a blast with it.
There is still a good bit to complete. Rerouting the gutters, finishing up some of the railing. I'll be re-plumbing the pump and chlorine generator to move them out of sight and put them under cover.
Sine_Qua_Non
Sine_Qua_Non SuperDork
7/1/18 4:36 p.m.
Where’s the water slide? Gotta have one. Get it done prontocheeky
Toyman01
Toyman01 MegaDork
7/1/18 4:54 p.m.
In reply to Sine_Qua_Non :
You know, I picked up a slide at the swap shop the last time a took oil to the recycle center.  I was going to mount it on the dock down at the family farm, but...
hobiercr
hobiercr SuperDork
7/2/18 10:02 a.m.
I like the pitch of the shop roof. I could see this getting out of hand.
akamcfly
akamcfly Dork
7/2/18 10:29 a.m.
Looks like the perfect distance to be a 50/50 shot of making it.
pinchvalve
pinchvalve MegaDork
7/2/18 10:34 a.m.
Uhhhh, can we come over?
xflowgolf
xflowgolf Dork
7/2/18 10:48 a.m.
This thread is relevant to my interests.  In-laws considered a big above ground, but ended up on the fence whether to do it or not after talking themselves up to a full fancy rectangular stainless fancy installed jobby with heaters and everything else coming in close to $10,000.  (in west Michigan).  While it was priced fairly relative to competitors for what they were looking at, it also caused them to end up not doing anything (for a number of reasons).
If I can put something in for ~$1,000 and it last a few years I'd just pay for it myself so the kids could go use it on days like this week when it's been silly hot.  HOA won't allow a pool at our own house, and grandma's just 15 minutes down the road.
Do you take it down in the winter?  Life expectancy?  Intrigued!
mtn
mtn MegaDork
7/2/18 10:53 a.m.
Can you teach me how to build a deck?
Toyman01
Toyman01 MegaDork
7/2/18 1:14 p.m.
In reply to mtn :
I didn't follow a particular plan. It mostly consists of some 2"x10"x16' joists, some 5/4"X6" decking, some 4"x4" posts and a lot of 3.5" screws. It's all sitting on 6"X4"X12" precast blocks dug down through the grass so they sit on the clay below. The deck is 16'x8' to make lumber buying easier.
It's basically put together like this less the steel joist hangers. I used wood cleats to hold it all together because I didn't want the pool salt dissolving the steel.
racerdave600
7/2/18 1:42 p.m.
Great job on the deck too!
MazdaFace
MazdaFace Dork
7/2/18 7:11 p.m.
Impressive setup! Deck looks great
Sine_Qua_Non
7/2/18 7:34 p.m.
Here is one way to bypass HOA rules.
i9SDSxowzP9Bv9blE0rbZSqGqKI3XuyGWwzWOQT3xkMLiswTJFXSrA9cmKIz3Afq
