Marty!
Marty! HalfDork
3/9/10 4:02 p.m.
I Googled the intraw3b and couldn't find any answers.
I have some 2 year old Meguiars Gold Class paste wax that has been through 2 WI winters in my garage. Is their a shelf life on wax? Any harm in using it?
I was going to replace it but good wax is pricey $$$$ and this one is almost full still.
EastCoastMojo
EastCoastMojo SuperDork
3/9/10 4:05 p.m.
I have used paste wax that was so old it had shrunk by about 10% and was rattling around in the tin. Worked fine. I wouldn't do that with a rubbing compound though but regular paste wax should be fine.
John Brown
John Brown SuperDork
3/9/10 4:44 p.m.
As long as the wax is free of debris I would use it. I have scraped off the top layer with a new bondo spreader, taken clean wax and scooped it into a ziplock bag and then kneaded the clean goop for consistency.
P71
P71 SuperDork
3/9/10 7:50 p.m.
Paste wax lasts longer than Twinkies on the shelf. Go for it!
foxtrapper
foxtrapper SuperDork
3/9/10 8:21 p.m.
Worse case, you heat it and re-melt it. Which works quite well. I've used waxes that were decades old.
AngryCorvair
AngryCorvair SuperDork
3/9/10 8:47 p.m.
foxtrapper wrote: Worse case, you heat it and re-melt it. Which works quite well. I've used waxes that were decades old.
+1
Marty!
Marty! HalfDork
3/9/10 8:53 p.m.
Thanks peeps. I will re-melt it tomorrow, Just have to wait 'til the wifey goes to work so I can use the oven.
porksboy
porksboy Dork
3/9/10 10:33 p.m.
Double boiler will work better than the oven. Use a sauce pan with water in it. Put the wax container in the water. water goes on the cook top/ stove top.
914Driver SuperDork
3/10/10 6:12 a.m.
Old wax can't be worse than no wax.
spitfirebill
spitfirebill Dork
3/10/10 8:39 a.m.
I consider two years to be new. I bet I have some wax older than some of the board members.
pinchvalve
pinchvalve SuperDork
3/10/10 8:46 a.m.
What's car wax? Does it make you go faster?
914Driver SuperDork
3/10/10 9:28 a.m.
pinchvalve wrote: What's car wax? Does it make you go faster?
Yes.
Lowers parasitic drag on all outside surfaces and makes your girlfriend slide more easily.
Dan
joey48442
joey48442 SuperDork
3/10/10 9:31 a.m.
I had some stuff get really runny after being in the garage through the winter, but other than that I've neve had a problem.
Joey
petegossett
petegossett SuperDork
3/10/10 11:03 a.m.
I've got some from the early 80's that was my father's. Even though I don't ever wax our cars, I keep as if I might get a sudden whim to do so. I'm a big fan of 'patina'.
Carson
Carson Dork
3/10/10 11:32 a.m.
Look at it this way: you didn't lose a wax, you gained a clay bar.
daytonaer
daytonaer Reader
3/10/10 11:45 a.m.
I found most of the wax more than 10yrs old is a good medium for mold. I think the petroleum evaporates and its yummy food for microbes. Or maybe basements are not for waxes. Years ago I added water to dried up turtle wax from the 70's, worked fine.
If its not moldy, mix it up and use it
Cone_Junky
Cone_Junky New Reader
3/10/10 3:33 p.m.
In reply to daytonaer:
other that the free samples, all my waxes are 2+ years old. Even have stuff that I remember being in the garage when I was a kid (20+ years old).
Lesley
Lesley SuperDork
3/10/10 4:25 p.m.
The only stuff I don't use is liquid polish that's been frozen. It separates and goes verrrry nasty, like clotted milk.
Uhd8vsHghnVgAyA4TSGNjuMWMh1P923vZhuQkcEGQqs0IoYh044slBcisM85Rz6x
