digdug18
digdug18 Dork
3/21/14 3:40 p.m.
But not wife a ladder and gloves mind you, no, that would be a thorough job and why would anyone do that. Instead I came home from pulling parts at the junk yard to her telling me she was working outside via text. I'm sitting down and I see her out the window with 2 broom handles duct taped together, and a hook shaped implement duct taped to the end. Sorta looks like a 180 degree curved aluminum piece that you would use to clean the gutters with water.
Well she's using that to swat at the debris, small twigs, maybe some leaves that decided to jump into the gutter in the winter. All I hear outside is metal on metal clanking together. I know I'm going to have to rehang the gutter in 2 hours.
dean1484
dean1484 PowerDork
3/21/14 4:07 p.m.
That rite there is funny. .. . And being married I can see that happening in my house. The real question is do you get involved or stand back and let her bask in the glory or her new found power.
You may want to infer that the lawn also will need mowing but weigh this carefully as sleeping on the couch for a while may be part of the equation. LOL
PubBurgers
PubBurgers Dork
3/21/14 5:24 p.m.
dean1484 wrote: The real question is do you get involved or stand back and let her bask in the glory or her new found power
Doesn't matter, it'll be his fault either way if things go wrong.
secretariata
secretariata HalfDork
3/21/14 5:35 p.m.
PubBurgers wrote: </cite Doesn't matter, it'll be his fault either way if things go wrong.
That is the TRUTH!
3/21/14 6:33 p.m.
Smile and nod, thank you honey. Sex by yourself isn't the same.
N Sperlo
N Sperlo MegaDork
3/21/14 6:36 p.m.
Pictures or it didn't happen.
Ian F
Ian F UltimaDork
3/21/14 7:19 p.m.
Dude... I wasn't married but after 11 years together let translate this for you: "Get out here and clean out the berking gutters!"
foxtrapper
foxtrapper PowerDork
3/21/14 7:21 p.m.
digdug18 wrote: I see her out the window with 2 broom handles duct taped together, and a hook shaped implement duct taped to the end.
Why isn't she on this forum? She sounds like one of us!
digdug18
digdug18 Dork
3/21/14 8:31 p.m.
The gutters are clean enough. I cleaned them at the end of the fall, right before it got really cold. I can't think that the snow would impart that many leaves on them.
Also I had an issue with a couple of the gutters not being properly pitched, so I pulled the gutters and rehung about 60ft across the front of my house, some of the side as well. I need to do it in other areas, but my wife is scared about being 4 feet high off the ground, so I have to devise systems for getting the gutter off and not bending it in half. Last time luckily the A-frame step ladder was within inches of the bottom of the gutter, so I loosened all the screws in the middle except the 2 at the far ends. Then I went to the end that needed to be dropped, and rehung it where I wanted it. Then fixed the other end, then reattached all the screws in between. Took a couple of hours.
Appleseed UltimaDork
3/21/14 10:17 p.m.
So what she decided is that you're cleaning the gutters.
1988RedT2
1988RedT2 PowerDork
3/21/14 10:49 p.m.
Ian F wrote: Dude... I wasn't married but after 11 years together let translate this for you: "Get out here and clean out the berking gutters!"
This. It seems to me that cleaning gutters is an easier task than re-installing or repairing them.
Ian F
Ian F UltimaDork
3/22/14 7:26 a.m.
digdug18 wrote: The gutters are clean enough.
This is your opinion, which you should know by now, ain't worth E36 M3.
SVreX
SVreX MegaDork
3/22/14 4:02 p.m.
An attitude like that could have a significant downward impact on your sex life.
digdug18
digdug18 Dork
3/23/14 7:55 p.m.
In reply to SVreX: I never said that to her, I just thought it to myself.
LdG2kwCa0i8VVS3cHzZXcSjTJMOxiq2BOZ8LOQWCRBaGX5bnUTuCkNo4e3Ig5LFw
