Japanspec
Japanspec Reader
2/8/25 9:49 p.m.
Hey guys, I just got some berryman's chem dip, and upon opening it I noticed its a dark color and has what looks like metallic flakes floating in it. Is this normal, or did I end up with a returned product that has been used?
https://youtube.com/shorts/9s1V-2URSMk?si=c5Y9Izl3w8Vs0L3q
Sorry wasn't sure if there was a way to parse the video here directly.
Japanspec
Japanspec Reader
2/8/25 10:29 p.m.
Hmm okay so I found on another forum someone mention that the chem dip has little gold flakes in it, which is what mine has as well. I guess thats normal?
MiniDave
MiniDave Dork
2/9/25 12:31 p.m.
Yes, that's what mine looked like too.......nasty looking stuff but it does work.
Japanspec
Japanspec Reader
2/9/25 12:52 p.m.
Awesome thanks, I'll get dipping then!
spitfirebill
spitfirebill MegaDork
2/10/25 12:41 p.m.
Not as good as it once did.  It used to have methylene chloride in it I think.
MiniDave
MiniDave Dork
2/12/25 11:31 a.m.
Yeah, I bought mine in the early 90's, so.......
NOHOME MegaDork
2/14/25 7:57 a.m.
Just read up on this stuff. Seems like nasty stuff to have around. The bit about not storing it on a metal shelf was worth learning. Anything that has to be stored in a fume-hood is probably best not to have in my shop. This does NOT read like a product that would be used in most day-to-day mechanic shops.
Safely:
  • Always use rubber gloves when handling.
  • Keep the area well-ventilated by either using the product outdoors, or opening up doors and windows.
  • When storing this product, it must be placed on a surface made of non-conductive material — such as wood, cardboard or plastic. Do not store Berryman Chem-Dip on a concrete floor or metal surface. If you do so, the compounds within it will react and may become deactivated, causing the product to lose its effectiveness.
  • When using Chem-Dip, keep the container in a hood or lab bench area that reduces the possibility of accidentally knocking it over.
Japanspec
Japanspec Reader
2/15/25 3:57 p.m.
Thanks guys! I ended up using it anyway and dipping the carb, but I also made sure to use the actual spray can of carb cleaner to get all the passages and the actual body of it rinsed out, and shot everything with compressed air. Seems okay so far. It does smell pretty nasty and I've been using gloves but its not too terrible. Well, doesn't seem like it is at least...
dBzQIp1OKDptbZ4cpUnByfb581J5hz5qtVG5yx1nkMnFdfmJtI9CuUgYYG5ORuwF
