gearheadmb
gearheadmb UltraDork
12/10/22 9:35 a.m.
What do you do for hardware and small part organization?
I have a couple of these type that are overflowing.
I want to go quite a bit bigger but I dont know what direction I want to go with it. I could get a couple more of what I have and build a shelves or a cabinet to hold them. I'm also considering building a big all wood setup with dividers like the parts department I've seen in old dealerships. Or I could build shelves to fit my needs and buy or collect little containers to fit. I saw one where a guy cut the tops off oil quarts so they were about 4" tall and used those on a shelves. That would be cheap and effective.  How do you do it and what would you do differently?
stafford1500
stafford1500 Dork
12/10/22 9:47 a.m.
https://www.uline.com/BL_8779/Bench-Panel-Racks
I have a similar system, just mounted to a wall plate. Different size containers available and you can lift them off and carry them to the project. I have smaller bins within each larger one for the small hardware like machine screws/nuts/washers.
gearheadmb
12/10/22 10:39 a.m.
I was just looking at this from HF I'm thinking maybe building a cabinet to house a couple of those with larger built in compartments in the bottom.
12/10/22 10:48 a.m.
In reply to stafford1500 :
The only downside is dust. If you do any sanding or grinding in the garage, they will collect dust.
stafford1500
stafford1500 Dork
12/10/22 11:39 a.m.
Appleseed,
There are  flip up lids available if dust is an issue. For my stuff, the dust settles to the bottom and is my reminder to resupply my stock.
I have min eright next to my fixture table so there is always griding dust and other stuff flying around.
KNx4TXDNDvn3XiBGbwRW4sTSLiFFfgeoD28BJUD1BDGEvG0pa2D0TsgGO8GgpMEI
