dannyp84
dannyp84 Reader
3/3/23 2:28 p.m.
My garage is approx 80' from the house, cell signal is lousy inside the building, and the wifi doesn't reach. I'd like to be able to stream music onto the stereo, and probably more important, I'd like to be able to make a phone call for help if I drop a vice on my toes or something. It seems like there are 100s of signal boosters available, but I'd like to hear some real world experiences and recommendations for what to avoid.  Cheers!
Spearfishin
Spearfishin New Reader
3/3/23 3:45 p.m.
We have Starlink and cell service in my steel building is non-existent, and the wifi didn't reach. We added the Starlink mesh router and just stuck it right in the window closest to the shop and we now at least have wifi in there.
Probably not the "best" solution, but it was pretty "easy" and IT isn't my strongest area, so easy counts for something.
birdmayne
birdmayne HalfDork
3/5/23 12:25 a.m.
I have the Google Mesh system in my houwe and shop. One close to the router and then a daisy chain along the house and to the shop. Probably 80' from router to shop link.
I stream movies, live sports, and do some light gaming with no issues.
eedavis
eedavis New Reader
3/5/23 8:37 a.m.
Little bit overkill* for 80', but I use a pair of these in a similar scenario. The one in the house is hardwired into a DSL modem, and the shop side is the network source for a wifi router for my phone, laptop, etc out there. The TP-Link connection is the most stable link in the chain, and I get full internet speed over the link (but that's <50mb/s since we're in a sparsely populated area).
https://www.tp-link.com/us/business-networking/outdoor-radio/cpe210/
I just have mine propped in windows generally pointing at each other, but the transceivers are weatherproof and could be mounted outdoors if needed to get LOS or if you don't have convenient windows.
Configuration could be quite complex, and the documentation reflects this. A basic/simplest-case setup is more involved than connecting to a wifi  router, say, but if you can read & follow directions it's doable.
* There's no kill like overkill, eh?  :)
dannyp84
dannyp84 Reader
3/5/23 11:07 p.m.
In reply to birdmayne :
I'll look into the mesh system, that sounds like the easiest method.
Wxdude10 - Mike
Wxdude10 - Mike HalfDork
3/6/23 8:34 a.m.
If you have power going to the shed, you could get some Powerline network adapters.  If you have an outlet at both ends of the feed, that would give you the best performance.  There might even be a Powerline wifi adapter that you could put at the shed end just to get wifi out there.
dannyp84
dannyp84 Reader
3/6/23 11:40 a.m.
The outdoor wifi extender looks like the easiest method, but I wonder if the garage's metal exterior will block the signal if I have the door shut. There is power in the garage.
whiskey_business
whiskey_business Reader
3/7/23 10:46 a.m.
No specific product recommendations, but find a WiFi extender with multiple removable antennae.
Put extender inside garage, with half the antennae attached to it and half of them outside the garage attached via extension cables.
Depending on the functions of the specific antennae, this should give good receiving signal strength from WiFi outside the garage, and good extended network strength inside.
mfennell
mfennell HalfDork
3/7/23 12:41 p.m.
I use a powerline adapter at home (https://www.amazon.com/gp/product/B08M13B8B6/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1) and love it.  Plug it in and ... that's it.  My previous setup lasted 8 years of continuous use before I replaced it, thinking it was getting flakey.  It's not clear it really was but for $60 I thought I'd upgrade.
The only 'gotcha' is you have to be sure the two outlets are on the same phase, assuming your house is wired for 240.  Just make sure they're on the same side of the breaker box.
Curtis73 (Forum Supporter)
3/7/23 2:31 p.m.
You can put a repeater in the garage with a higher gain antenna.  By default, wifi antennas are omnidirectional, meaning they're spewing Tx in all directions and also looking for Rx in all directions.  If you use an Rx antenna that is directional pointed toward the house, it should work.  I did this at camp.  The wifi is about 500' from me and obscured by a hill.  I just shimmied up a pole and put a Yagi antenna pointed at the source.
earlybroncoguy1
earlybroncoguy1 Reader
10/30/23 8:50 p.m.
That's pretty much what I did for my metal shop, about 60-70 feet away from the house - wifi extender on the inside wall nearest the house, cable runs through wall to outside antenna pointed at house. Signal is good enough to stream video and music, and surf the web.
brandonsmash
brandonsmash New Reader
11/1/23 8:37 p.m.
My setup is quite similar to a lot of yours. I tried TP-Link extenders, but they were garbage. Then I switched to an Amazon eero mesh system (one connected to the primary router, one about 50' away, the one in the shop about 50' away from the second one).
It is also garbage.
StuntmanMike
StuntmanMike New Reader
11/2/23 9:17 a.m.
I ran an extra conduit to my detached garage with a couple CAT 6 cables and used an extra wireless router that had laying around for wifi just in the garage. You can also buy decent wireless routers for a good price. If you can't drop a conduit at this point the mesh wireless is probably your best option.
glyn ellis
glyn ellis New Reader
11/2/23 1:21 p.m.
I had an attached garage with block walls and a concrete roof, and used a Netgear Powerline wifi extender (similar to this one https://www.amazon.com/NETGEAR-Powerline-802-11ac-Gigabit-PLW1000-100NAS/dp/B01B5CTRGE/ref=sr_1_16?crid=COSTCZS7E2OK&keywords=TL-WPA8630&qid=1698945469&sprefix=tl-wpa8630%2Caps%2C87&sr=8-16&ufe=app_do%3Aamzn1.fos.006c50ae-5d4c-4777-9bc0-4513d670b6bc&th=1) with great success. . Only took it out when I moved house last month. The only drawback was it was its own network, and so you needed to make sure that your phone had switched over to it. I'm planning on using it in the basement of my new house.
jfryjfry
jfryjfry UltraDork
2/2/25 10:02 a.m.
Wondering if there were any updates to this question??
im finally at the point of addressing the same issue for us:  getting a better Wi-Fi signal in a metal garage about 50' and a house wall away from the router.
bonus would be a system that could also get a better signal to our driveway (a wireless cam) that's 50' away and 90* from the garage.
NermalSnert (Forum Supporter)
NermalSnert (Forum Supporter) Dork
2/2/25 10:31 a.m.
Our fiber optic cable runs to a router in the shop. I put a wireless repeater in the little shovel shed about 12' away. From there to the house is 130' or so. No problem getting a signal especially in the near room. The reverse of what you are trying to do.
jfryjfry
jfryjfry UltraDork
2/6/25 11:09 p.m.
well, i tried an eeros mesh system and maybe i need more of them, but it has two parts and i had no luck getting it into the garage when closed up, about 60' away from the router.
I feel like there must be something i can attach to the outside, then run a cable through the wall to something inside....
I have line of sight from one part of the garage to the router  in the  house (through a window).
I'm seeing a bunch of different options but seems like there has got to be a pretty simple solution....
CJ
CJ Dork
2/6/25 11:58 p.m.
If you could install Direct Burial Shielded Cat 6 cable, it would solve all your problems.  Dig a trench, throw in the cable, hook it up and rock.
The other option is to get a couple of yagi antennas and mount them outside the buildings, connecting the leads to a repeater on either end.  I did this to bridge a 1/2 mile gap between buildings at a school site and and was able to get 100mbps over the link using parts we had laying around.
Wire is always best.  Failing that, a yagi repeater setup.  Getting the antennas outside the building envelope is critical - wifi hates metal buildings.
dherr (Forum Supporter)
dherr (Forum Supporter) SuperDork
2/7/25 9:53 a.m.
I gave up and had Comcast put internet in my shop...... works 100% now. Metal building was just too far away, I considered running an ethernet cable to the shop, but in the end, was just easier to expense it to the "business".
BoxheadTim
BoxheadTim MegaDork
2/7/25 9:57 a.m.
Wires are usually your friend in these situations. Ubiquiti makes a wireless building bridge for those sorts of situations but they're not exactly cheap. Plus I suspect you'll need a WiFi AP inside the metal building because it's going to act like a Faraday cage.
chinchillawikinson
chinchillawikinson New Reader
3/26/25 2:10 a.m.
I suppose for better Wi-Fi coverage in your garage, you can use a Wi-Fi extender or a mesh network that will extend your home Wi-Fi signal. For instance, TP-Link Deco X20 (Mesh Network) is a solid and affordable mesh option. You can place a unit closer to the garage to ensure the signal gets through.
EbaPBDIFDUYdFNqK1LGjLMD0vThNLBeY7RDR95n3Hj1HyhkYhK194sxlwxba8sP5
