4 5 6 7
BradLTL
BradLTL SuperDork
5/7/19 9:20 p.m.
Next Friday
Argo1
Argo1 UltraDork
5/7/19 9:23 p.m.
Sonoma.  June 9th 1:00pm.  Mostly cloudy.
Argo1
Argo1 UltraDork
5/7/19 9:32 p.m.
I think that the Ford is probably fast if I can come to terms with it.  Since I drive only from the cockpit view, it has the disadvantage of a large blind spot looking to the apex of left-hand turns.
T.J.
T.J. MegaDork
5/8/19 5:13 p.m.
In reply to Argo1 :
Try moving the seat forward.
T.J.
T.J. MegaDork
5/8/19 5:14 p.m.
If I am still awake, I’ll be on tonight. Home from AZ.
BradLTL
BradLTL SuperDork
5/8/19 5:44 p.m.
T.J. said:
In reply to Argo1 :
You’ll have to make sure you have buttons mapped for those controls.
Argo1
Argo1 UltraDork
5/8/19 7:11 p.m.
Screwed.  Can't map buttons on my Fanatec running through DriveHub.
On the road.  Will miss tonight.
BradLTL
BradLTL SuperDork
5/8/19 7:16 p.m.
In reply to Argo1 :
You should be able to map controllers buttons as well.
Argo1
Argo1 UltraDork
5/8/19 10:06 p.m.
In reply to BradLTL :
Yes, but that disables the wheel.  Reboot.  Lather, rinse, repeat.
aircooled
aircooled MegaDork
5/8/19 11:46 p.m.
Someone we meet online suggested plugging in a keyboard and mapping features to that. I need to try that since I have no reset button currently.  I have not tried it with the drivehub, but it should work since it’s not a controller.
T.J.
T.J. MegaDork
5/9/19 8:50 a.m.
The seat position seems to get saved for each car, so you only have to set it once. You could just use a controller, map the fwd/back, up/down buttons to the D pad, move the seat where you like it then exit. Then reboot or whatever you have to do to make drivehub happy and your seat should be where you want it. Should be a one time evolution (at least for the particular car).
T.J.
T.J. MegaDork
5/9/19 8:51 a.m.
I've got a lot of work to catch up on after taking 4 days off of work, but hopefully I can make some time to figure out a track and weather combo that I like.
aircooled
aircooled MegaDork
5/9/19 11:03 a.m.
TJ, try the B tune I sent you.  I was able to make the entire race without a spin,  It has very good turn in and might need some tuning for power out of the turn.  The only issue I had was when the tires started getting a bit slick which was probably them getting a bit hot.
Do check the radiator and brake openings, on one of the tunes both are set to zero.  The brakes are also too sensitive on one of the tunes.
T.J.
T.J. MegaDork
5/9/19 11:04 a.m.
In reply to aircooled :
I'll give it a try.
EDIT: I like the B setup. I changed it a bit with slightly different spring, shock, engine braking and diff settings and it is nice at Barcelona. Did a couple laps at Sonoma with Argo's date/weather and it seems pretty good there as well. I'll send it to you so you can check it out, but you'll probably like it your way better since I mostly made it a little less oversteery.
BradLTL
BradLTL SuperDork
5/9/19 7:03 p.m.
My round:
Road America
May 23, 2018 @ 6:00
Hazy to light clouds
T.J.
T.J. MegaDork
5/10/19 6:51 a.m.
I like the two tracks posted so far. Sonoma is fun and I've wanted to do over at Road America since out GT1 race there.
I'll post mine later today. I've got it down to a few tracks.
EDIT: Not sure there is a track where the 911 will have an advantage, so trying to pick one that is fun to drive and that we haven't used before. Been trying out some of the alternate configurations of tracks we have used.
Spoolpigeon
Spoolpigeon PowerDork
5/10/19 1:08 p.m.
I did some trolling at NCM today.
Thats Spyhunter’s ND.
BradLTL
BradLTL SuperDork
5/10/19 1:15 p.m.
In reply to Spoolpigeon :
Well played.  Now I just need to find a picture of you driving so we can write "That guy is slow in Project Cars"  devil
Spoolpigeon
5/10/19 1:59 p.m.
Lmao, for sure. I was certainly behind the curve on that game.
BradLTL
BradLTL SuperDork
5/10/19 2:00 p.m.
Are you running One Lap?
Spoolpigeon
5/10/19 2:52 p.m.
No, just there to watch. I’m local to NCM.
I love the idea of doing OLOA, but an old back injury makes road trips fairly miserable.
dean1484
dean1484 MegaDork
5/10/19 5:42 p.m.
Bathurst.
January 24th 2017.
Noon
No time change
sunny
dean1484
dean1484 MegaDork
5/10/19 5:43 p.m.
Am or pm brad for your choice.
BradLTL
BradLTL SuperDork
5/10/19 6:19 p.m.
Noon AM?
BradLTL
BradLTL SuperDork
5/10/19 6:22 p.m.
Times in PC2 are on 24 cycle. 6:00 is AM.
Just reread and figured out what your question.
4 5 6 7
s8CkMbdpHL0C8s1MCj78b7BIM11jbDU2Hd8j7oo1zCsuN4VvLj0yO56Xyz6GGvhv
