FSP_ZX2
FSP_ZX2 Dork
8/19/17 10:54 a.m.
I have seen in other corners of the interwebz that it is pretty popular to use diesel oil (Rotella/Delo/Delvac etc) in wet clutch motorcycle applications.
I have also heard that the diesel oil is not necessarily good with catalytic converters (which are on most light duty diesel vehicles nowadays).
Am I looking for trouble if I use one of the above in a late-model bike? My bike calls for 10W-30, and as motorcycle oils go, that is an unusual weight. Its readily available in Diesel oil.
BoxheadTim
BoxheadTim MegaDork
8/19/17 11:26 a.m.
Like everything on the Internet, you'll find some vocal opinions either way. With wet clutch bikes I personally tend to stick with m/c specific oil, but that's just me. Any reason you can't just use 10W40 instead of 10W30?
BrokenYugo
BrokenYugo MegaDork
8/19/17 11:38 a.m.
Diesel oil isn't loaded with ZDDP anymore (which is bad for cats if you're burning oil), with the new CK4 spec anything gas/diesel dual rated is 800ppm phosphorus max, Rotella is a bit higher since they dropped the gas rating from most of their oils. They've moved on to better ep wear additives.
Rodan
Rodan Reader
8/19/17 3:30 p.m.
I've been using Rotella T6 (synth) in all my street bikes since ~ 2000. No issues, although the only bike I've owned with a cat is my current ride ('15 FJ-09), which only has ~12k miles. Working great so far.
cabbagecop
cabbagecop New Reader
8/19/17 4:30 p.m.
Most of the Rotella oils are JASO rated which is the Japanese motorcycle wet clutch spec so they should be ok.
WOW Really Paul?
WOW Really Paul? MegaDork
8/20/17 1:02 a.m.
In reply to cabbagecop:
Surprisingly not all of them, it is a look closely type of thing.
Huckleberry
Huckleberry MegaDork
8/20/17 6:54 a.m.
Amazon makes finding the right oil easy as pie. Why not just get what it calls for?
7ulePNIzzyZKeqOCzK69WzOl4f0tNPQiCNdNBLmT6qua9LbDSSmuGhl5L3hnunTy
