Donebrokeit
Donebrokeit HalfDork
6/10/13 10:35 p.m.
Why do we (U.S.A) not have this?
This sounds like a great bike on paper but at this time the bike is not coming to the states. So sad.
http://www.ktm.com/gb/naked-bike/990-super-duke-r-ausuk/highlights.html#prettyPhoto
TECHNICAL DETAILS ENGINE Design 2-cylinder, 4-stroke, spark-ignition engine, 75° V arrangement, liquid-cooled Displacement 999 cm³ Bore 101 mm Stroke 62.4 mm Performance 92 kW (123 hp) Starting aid Electric starter Engine lubrication Dry-sump lubrication with 2 rotor pumps Primary gear ratio 35:67 Secondary gear ratio 16:38 Cooling system Liquid cooling system, continuous circulation of cooling liquid with water pump Clutch Wet multi-disc clutch / hydraulically operated Ignition system Contactless, controlled, fully electronic ignition system with digital ignition timing adjustment CHASSIS Frame Tubular space frame made from chrome molybdenum steel, powder-coated Fork WP Suspension Up Side Down Shock absorber WP Suspension Monoshock Suspension travel front 135 mm Suspension travel rear 150 mm Brake system front Twin-disc brake with radially mounted four-piston brake calipers Brake system rear Single-disc brake with one-piston brake caliper Brake discs - diameter front 320 mm Brake discs - diameter rear 240 mm Chain 5/8 x 5/16” X‑Ring Steering head angle 67.3° Wheel base 1,450±10 mm Ground clearance (unloaded) 150 mm Seat height (unloaded) 850 mm Total fuel tank capacity approx. 18.5 l Unleaded premium fuel (95 RON) Weight without fuel approx. 186 kg
mistanfo
mistanfo SuperDork
6/12/13 5:41 p.m.
Because those are two different bikes pictured? One has a single sided swingarm, the other may, but it would be the other side...
And because we are a litigious society that doesn't get the nice things.
lightitup
lightitup New Reader
6/12/13 11:15 p.m.
looks like the one with the single sided swingarm is a different model
Donebrokeit
6/13/13 9:14 p.m.
I suck Wrong hot link :(
I think mistanfo cleared this one up. "And because we are a litigious society that doesn't get the nice things. "
Mitchell
Mitchell SuperDork
6/16/13 1:21 p.m.
I don't know if we can blame the US GOV for not getting this one. How many ridiculous super sport bikes do we have here nowadays?
Rusnak_322
Rusnak_322 HalfDork
6/17/13 12:09 p.m.
You can blame the US motorcycle buying population. If there was a market for the SuperDuke R, then I am sure that it would be on sale here.
But that bike is going to be up against the Streetfighter (with the important Ducati name on the tank). the Triumph Speed Triple R, the Aprilia Tuono, MV Agusta, BRUTALE RR 1090 all of which will have WAY more then 123 hp.
When is BMW going to make a naked version of the S1000RR?
Zomby Woof
Zomby Woof UberDork
6/17/13 12:33 p.m.
Rusnak_322 wrote: You can blame the US motorcycle buying population. If there was a market for the SuperDuke R, then I am sure that it would be on sale here.
That's exactly what it is.
Beer Baron
Beer Baron UltimaDork
6/17/13 1:24 p.m.
Rusnak_322 wrote: You can blame the US motorcycle buying population. If there was a market for the SuperDuke R, then I am sure that it would be on sale here. But that bike is going to be up against the Streetfighter (with the important Ducati name on the tank). the Triumph Speed Triple R, the Aprilia Tuono, MV Agusta, BRUTALE RR 1090 all of which will have WAY more then 123 hp.
And slots in just above the Street Triple R, Ducati Monster, and SFV650... all of which way undercut it on price.
Flight Service
Flight Service MegaDork
6/17/13 1:30 p.m.
Rusnak_322 wrote: You can blame the US motorcycle buying population. If there was a market for the SuperDuke R, then I am sure that it would be on sale here. But that bike is going to be up against the Streetfighter (with the important Ducati name on the tank). the Triumph Speed Triple R, the Aprilia Tuono, MV Agusta, BRUTALE RR 1090 all of which will have WAY more then 123 hp. When is BMW going to make a naked version of the S1000RR?
and of those listed only the Speed Triple would be considered a success
singleslammer
singleslammer Dork
6/17/13 1:38 p.m.
In reply to Flight Service:
I would guess that has a lot to do with the price though.
Rusnak_322
Rusnak_322 HalfDork
6/17/13 2:02 p.m.
Depends on what criteria you are defining success. All of the bikes I mentioned are based on open class sport bikes except the triumph. That means the cost to develop is born solely on the Speed Triple and not spread out. The street triple has the Daytona 675, but I don't think that there is a big Daytona anymore.
Flight Service
6/17/13 2:18 p.m.
In reply to singleslammer:
price, service network and availability.
yamaha
yamaha UberDork
6/26/13 10:52 a.m.
I love the new looks of the ktm rc8, but berkeley paying $16k for one new. I'd rather have the bmw or MV f4 for a bit more than that.
FWIW, Isn't the speed triple loosely related to the triumph ST tourer?
Beer Baron
6/26/13 2:00 p.m.
yamaha wrote: FWIW, Isn't the speed triple loosely related to the triumph ST tourer?
The engines are related, but I'm pretty sure that's about it.
Gasoline
Gasoline Dork
6/26/13 2:18 p.m.
The video makes me think I would be a better rider if I had one. The Beast Escapes
yamaha
yamaha UberDork
6/27/13 1:21 p.m.
Ahh, I figured more would be shared.....but then again, the speed triple seems to have been a winner for them
Beer Baron
6/27/13 2:39 p.m.
yamaha wrote: Ahh, I figured more would be shared.....but then again, the speed triple seems to have been a winner for them
Pretty sure the Speed started out based on the Daytona 955. Not sure how closely the Sprint was based on the same platform. I would imagine that the frame would be fairly significantly modified for the very different application.
FsJD113CwlM7GNOPaKjC8Lppp3KmLRboLfkPPiqwLmCYHMS9yud8cuv6aOOa4aJh
