I'd like my new SV650's exhaust to be slightly louder. Keyword: slightly. None of the brands I look at have anything in the way of actual decibel readings, and I can't find any hard reviews to find out the same.
Where's the best place to start looking for a not-too-loud exhaust replacement?
Avoid anything that says "D&D" or GP style.
I have a D&D pipe and it's deafening.
Jardon has been recommended to me a few times.
Electric drill. Poke a hole in your existing baffle and see if you like the louder sound. If you don't, run a screw into the hole to close it back up.
pres589
SuperDork
6/11/13 7:58 p.m.
Jardine does make some decent sounding exhausts that are not too loud and aren't very expensive either. The new Apex stuff from FMF is really interesting and might be worth a look, but I couldn't find a video of anyone running one on an SV650.
I had a Yosh on my SV race bike that sounded great.
Look for pipes with removable DB inserts. I have those on my bike now and it makes a huge difference between in and out. It removes with a single set screw.
That sounds like the direction I'd like to go. With the insert in are they actually reasonable though, or just two shades of loud?
I put on the Leo Vince italia
http://www.motorcycle-superstore.com/14/70/945/55385/ITEM/Leo-Vince-Italia-Slip-On-Exhaust.aspx
on my 09 ZX-6R. It sounds great, comes with a removeable silencer. Lounder than stock but not by a huge amount.
I just put a yoshimura on my buddies sfv650, same motor as the sv, and with the baffle in its actually not too much louder than stock, it sounds a lot better though. On the other hand, I have yoshimura rs3's on my rc51 and they are pretty loud, no baffles though.
I'm curious about this as well. I have a 400cc Bandit with a full Vance & Hines system that will make your ears bleed (not good)......but on the plus side, it sounds like an IndyCar. It really needs a dB reduction, badly. I'm wondering if a Yoshimura RS-3 w/insert would slip on in place of the V&H muffler (keeping the V&H header/midpipe) and makes things a little more tolerable. Looking at their website:
http://www.yoshimura-rd.com/t-replacement_muffler_RS3.aspx
The only difference I see is 18" vs. 20", does the pipe inlet diameter not matter for a slip on? Or do they just not have an online configurator?
how old is your Vance & Hines? May just need to re-pack it.
pres589
SuperDork
6/13/13 3:08 p.m.
In reply to ahutson03:
RC51's with cans like those RS3's sound amazingly nice. I really like how those bikes sound with aftermarket exhausts.
Just re-packed this season, unfortunately. That's what I was hoping too
does anyone in the aftermarket make a baffled muffler, similar to stock, that flow some more and aren't nearly as loud as true aftermarket straight through exhaust? I'd really like to find a megaphone style pipe that didn't require repacking and was slightly louder than stock pipe so I can give my nighthawk a bit more growl. maybe a used stock muffler from a Sportster or something?
The key here will be to buy something with a removable baffle as others have said so you can control the sound. Motorcycle aftermarket exhausts are generally loud. The ones with baffles at least allow you to make them not-so-loud.
Oh don't get me wrong I love how it sounds, probably the nicest sounding mechanical thing I've eer owned, it is loud though
