Does anyone have any opinions on this?
I'd like to get a motorcycle so I can go out riding with friends and my bro. However, I've got a couple of other project cars and don't want to take too much spare change away from them. Don't have a lot of seat time but have been thru the MSF class and have the class M endorsement already. Would like something that's easy to work on, easy to find parts, and lets face it - easy to modify. I'm leaning towards a Kawasaki KZ. Thoughts?
Thanks!
Woody
SuperDork
12/8/09 11:59 a.m.
EX500. Plentiful and dirt cheap.
The deciding factor is your $1k budget. Go to Craigslist, sort out the bikes selling for less than that and see what there is to choose from. I just checked in my area and right now there's not much to choose from in that price range. I did find an '84 Honda 650 Nighthawk and an early 80s GS550 Suzuki, both of which would be decent bikes.
I've ridden my EX500 for 11,000 miles in the last 2 seasons. just put in the back of the Garage last tuesday.
Cheap, plentiful, zippy....40-75mpg depending on how you ride
You can get a decent motorcycle for under 1k but it won't be sexy, speedy, or exceptional. In my area most of the sub $1k bikes are japanese and from the late 70's to early 80's. I'd look for CB500's and CB550's. I like those. The Kawasaki EX series are pretty awesome too. You could find one of those in that range if it were in rough shape.
Last summer I found a 01 Buell S3T for $1200. It wasn't running and had a blown rear shock. I brought it back to life and now have $2500 in it. The point to that story is that you can find deals if you look long enough.
Spend a little more for a 1st Gen SV650.
I got an 86 nighthawk 450 for $650. All I have to do was recover the seat and clean up the carbs. I'm 6' and can ride the thing all day. Pretty ballsy too for a 450, gets 50mpg too.
I always throw the Honda CX500 out there. I got mine from a friend, so I never did any research into the matter, but excellent examples are available for under $1K any day of the week. The general consensus is that they are not too pretty, but I kinda dig it. No doubt that they are reliable as a brick, they will run forever with minimal effort. Only 500cc, but they put out 50hp and 50ft lb of torque...plenty for most things. The GL-650 is similar, only more so.
That inexpensive now? I was going to vote for the EX500, too.
Woody
SuperDork
12/8/09 9:23 p.m.
And the CX500 is water cooled, so it should last even longer than most Hondas. It's also shaft drive. It is ugly, though, and it has a bunch of cheesy stamped metal controls, as I recall. I can't imagine that the best one in the world would cost $1000.
I would tend to avoid the CX500/GL650 series unless it is a really low mileage example. I have had several of them and really liked them, but there are some service issues that you should be aware of:
1. Fan - attached to the camshaft and the plastic is pressed onto a metal hub that can seperate.
2. Water pump and Carbs - Water pumps do go out and the carbs tend to gum up causing rough running at best.
3. This is the PIA - Camshaft chain and tensioner -these do wear out and the engine must be dropped and cases split to get to these.
Othwise, I put over 105k on one and 65k on another.
XS 650. Can be made into anything from a cafe racer or a clubman to a bobber or a chopper. And they have the classic brit look to them.
racerboy000 wrote:
ninja 500
AKA EX500 (it's true name)
3 was only an issue on earlier models, and most were repaired under warranty. Look for three dots stamped into the case housing to verify that it was done.
I have never heard of the other two issues, but I will certainly keep an eye on them from now on! Thanks.
Woody
SuperDork
12/9/09 10:08 a.m.
Grtechguy wrote:
racerboy000 wrote:
ninja 500
Yup. But they probably cost twice as much when they're called Ninja 500's. Buy an older EX500 and some Ninja stickers.
I really like the SV650's and would take one in a heartbeat, but, I have not seen too many for under $2500. I want to stick pretty hard and fast to the sub $1k. I want to make sure that I am going to ride it and the great thing I have seen about the sub $1k bikes is, you can ride them for a year or two and then sell 'em and the only money you might be out is for consumables and insurance.
Besides, if I have a cheap bike, it'll be easier for me to justify keeping it in a few years when I buy a Duc 748
Thanks for the ideas so far.
How far is your commute? If no interstate...
Look for a Honda Helix, they look funny, but ride like a Goldwing. Built in trunk, 1 cylinder, 1 carb, 1 coil, belt drive automatic. Basic, easy to work on and Honda reliable. They top out around 70mph, get 50-70mpg, and were sold nearly unchanged for 20 years.
When I was looking for mine, I was finding mild project Curvies for around $1k.
CLynn85
New Reader
12/9/09 9:23 p.m.
I picked up my KZ440 for $700 and love it so far. Just get any 80's UJM that's been on the road for a while and hasn't been sitting in some barn. Unless you want a project....
only thing about some of the older bikes is finding parts
EX500 would be my vote. If you go the 80s UJM route make sure it is a running bike without rust in the tank. The
UJMs are great bikes but parts can be high for simple things like carb & fuel tap rebuild kits. Run from non running projects even if the miles are low. I have been down this road before. May be worth spending a little more.
Do take the MSF class! RIDE AT YOUR PACE. Have fun & be safe.
Actually did take the MSF's class a few years ago. It was pretty fun. Several people there had been riding for years.
Kawasaki 750 Spectre
Girlfriend & family got it for me for Christmas.
PHeller
HalfDork
12/27/09 1:45 p.m.
Bought my CB360 for $400 and have been trying to sell for $600
