NermalSnert (Forum Supporter)
NermalSnert (Forum Supporter) HalfDork
8/6/24 2:11 p.m.
The '56 Fleetwood needs a new or rebuilt harmonic balancer. I got the crank bolt loose but discovered that it stuck again after a half a turn or so. I ended up spending over an hour rocking it back and forth until I finally got it out. The bolt is stipped and must have been put back in that way years ago.
My question is, what do I want to clean up the threads in the crankshaft? A blind hole tap, thread chaser, ???
WonkoTheSane
WonkoTheSane UltraDork
8/6/24 2:54 p.m.
Thread chaser if you can.   A tap runs the risk of cross-threading by cutting a new spiral off from the original if the entry is really buggered.
A chaser is designed to not cut fresh, but straighten, so I don't think you could do that with a chaser if you tried, though I'm always amazed at how hard some people try...
8/6/24 4:14 p.m.
In reply to WonkoTheSane :
Thank you!
PODJxguGUoXvl9ZRI1yrAsI5iSJFv64dlghUJlo8SmBv4fKHKZzBzF6hxPSrrDHS
