Crazier
Crazier Reader
1/20/19 6:38 p.m.
Potential challenge car.
Ive bought a 1999 grand prix with a built motor and speed parts but bad trailing arm mounts.
I just went and looked at a 1997 grand am circle car with a full cage and a bad trans. Comes with a quad4 motor, needs some rust repair in the floor and the rockers are gone but the trailing arm mounts look solid.
If i read everything right i can drop the cradle and swap the motor and trans/struts ect all in one go?
Are the quad4 and 3800 harness and ECM anything close to each other? I can of course pull the whole harness from the grand prix,
But it sure would be easier if the harness and PCM were compatible with a few changes?
Also... This car has a cage that goes all the way to a loop that runs through tbe fender and up all the way around the radiator saddle and back all the way to the bumpers. Do you think i could just run a couple new bars down to the trailing arm mounts?
Any help appreciated!
Dusterbd13-michael
Dusterbd13-michael MegaDork
1/20/19 6:41 p.m.
Harness and ecm are radically different.
Need pictures of the cage.
Whats the end goal?
Crazier
Crazier Reader
1/20/19 8:24 p.m.
[URL=https://beta.photobucket.com/u/rbates74/p/45c1e4e7-b4a6-4b5f-adc6-3cd806db3d5c][/URL]
[URL=https://beta.photobucket.com/u/rbates74/p/78dabc5d-f31f-4143-924a-44c06163d20c][/URL]
Goal is to go silly fast stupid cheap and very safely.
I was misinformed on the grand am and grand prix sharing engine cradles? So that would not be a direct swap. But they were both available wkth the 4t60 so my engine and trans should fit in tbe grand am cradle?
ASfvOP9BLzeHxR05lXSMDzNrVk56QXEJCBtWLzQdsPCu0fonZCxOARPwuYNWiCrv
