kylini
Reader
2/21/15 5:51 p.m.
I'm smart. Real smart. I took the valve cover off my 1999 Miata and, thinking I might as well paint it this time, I decided to twist off the metal nipple with vice grips.
So... apparently this isn't a replaceable part. I just crushed mine to oblivion so I can't exactly JB Weld it back on. Supposedly, the original is pressed into the valve cover.
1) Where on earth do I buy a new valve cover vent nipple? This is the metal tube sticking out of the driver side, which normally spits into a hose that recycles into the intake before the throttle body.
2) If by some miracle I buy one, how do I install it into my valve cover?
3) If I'm totally screwed, anyone got a non-VVT valve cover for cheap?!
How big is the hole? Hose size? You can probably get a barb from the hardware store/home depot that you can epoxy in or tap the hole for.
Tap it, insert barbed fitting.
Woody
MegaDork
2/21/15 6:40 p.m.
Figure out what size it is and check Grainger or McMaster Carr.
kylini
Reader
2/21/15 7:19 p.m.
I like this line of thinking. I'm currently stuck on the last baffle screw (I reassembled it pretty tightly last time...). I'll bring it to a hardware store tomorrow and get something that'll fit.
kylini
HalfDork
2/22/15 2:57 p.m.
Great success! Yes, I tapped the hole in the middle of an Ace Hardware. I'll use JB Weld to reinforce the new barbed fitting because 1/8th threads are only barely larger than the original hole.
