wheelsmithy
wheelsmithy HalfDork
2/6/15 8:18 p.m.
Shove a bunch of grease into the pilot bushing/bearing hole, get a bolt that snugly fits the hole, and whack with a hammer. Repack, and hit more as needed. ....pushes it right out without need for a puller. Did GRM cover this in there miracles of grease article years go? No plagiarism intended.
2/6/15 9:02 p.m.
I've done this. It's a highly entertaining trick.
SnowMongoose
SnowMongoose Dork
2/6/15 9:22 p.m.
erohslc
erohslc Dork
2/7/15 8:49 a.m.
Wish I had remembered this one on my Mazda B2500 clutch job.
The stock pilot is a roller, which was thoroughly embedded.
I wound up using a HF slidehammer, the smaller one since it had the pair puller jaws that would fit inside the pilot hole.
Took a LOT of hard slams, in fact the center puller bolt broke at the threads, good thing I had another bolt.
daeman
daeman Reader
2/8/15 5:22 p.m.
Good tip, it works a charm. Wet newspaper also serves very well for this trick.
Brokeback
Brokeback Reader
2/8/15 5:33 p.m.
I've heard newspaper as well as crayons - haven't tried either I just ended up using a puller/slide hammer.
KjyKkpYND9fhhhUypmXaXrOTU3T5uRIj2jKJuR2DcxoYqYDE3NU3wdA9gXu3mTEm
